Power steering pump for 65 coupe lhd
Author Topic: Power steering pump for 65 coupe lhd  (Read 1551 times)
Offline Sally
  • Name: Chris, Sally
« on: January 18, 2021, 12:22:54 pm »
Hi
I installed an RRS pws kit but used my old ford pump but not happy with it.  What are other people using on their cars and is there any suggestions as to what i can pair my system with
Thankyou  Chris
Offline USA066
  • Robbo
  • Name: Colin
Re: Power steering pump for 65 coupe lhd
« Reply #1 on: January 18, 2021, 02:19:55 pm »
Chris,
I used an RRS pump with my RRS pws kit. Expensive at about $700 but well worth it. The problem with the old pump is that they don’t put out consistent pressure, which means your steering won’t be smooth. Just not up the task.
The only thing I don’t like about the RRS pump is the cheap Ford style reservoir. I replaced it with a nice Aeroflow polished aluminium reservoir. You could also try finding a pump with a built in reservoir, similar to GM ones.
When I get a chance, will post a pic of my setup.
Colin
2007 GT Convertible
2008 Bullitt
1966 Coupe
Offline USA066
  • Robbo
  • Name: Colin
« Reply #2 on: January 18, 2021, 06:23:29 pm »
Pic of reservoir setup
2007 GT Convertible
2008 Bullitt
1966 Coupe
Offline trav68
« Reply #3 on: January 19, 2021, 08:55:33 pm »
KRC Racing - adjustable flow control and pressure so they can be paired up with requirements or rack/box.
Offline sms777
« Reply #4 on: January 19, 2021, 11:16:05 pm »
A simple GM style Saginaw pump and brackets to suit is all you need. Costs about $400 all up.
