Bottom line factory 24" 3 core wasn't doing the job and this radiator does with A/C running.
That's because that aluminum rad has more volume/tube area than your stock rad, so you are not comparing apples to apples, if you had a 5 row stock rad, or a 4 row high efficiency rad, you would notice absolutely zero difference between those and the aluminum one.
