Thanks again for input, putting the crank you suggest would stroke it out to what cap? and the figures l am getting back are pretty large so an additional crank could blow the budget I am still at an early stage of research and the extra dollars for the extra horses could go to something else, Decisions Decisions,
Thanks Guys...,
i build a lot of high horse engines and shaunp and a few others here do also and they know their stuff, and if i were building a big horse 289, which i have before, i would install steel main caps which is going to cost you some big bucks.
CRANKSHAFT
the other big weak part in a big horse 289 is the crank unless you want to pay $2000.00 usd for a billet one, because the only 289 cranks that are available are the stock ones, and i have seen several break.
its also best to use a neutral/internal balanced rotating assembly on a big horse 289 and it costs big bucks to do that, especially in oz.
the point is that you can build a 347 for around the same money as a big horse 289 and neither will be "cheap".
BUDGET PARTS
on a stroker, you can save a little money using chinese heads and a cast chinese crank.
on a big horse 289 you can save some money using world products or similar cast iron heads but that will make it even harder to reach your horsepower goal so i don't see any point in doing that.
you can also save a lot of money using a non roller cam. if you do that with a 289 you have to use a solid lifter cam and higher ratio rocker arms to get close to your goal, but the rocker arms aren't a big deal cost wise because the high ratio ones cost around the same as the stock ratio ones.
a decent carb for either build will cost at least $600.00 usd. you need to use one that does not have a choke tower on it but you can buy a cheaper carb and cut the tower off.
GEAR RATIO
If you build a moderate hp 347 (around 350 hp) and use a 5 speed trans, you can get away with around 3.25 gears and it will still accelerate hard and still rev low on the freeway due to the overdrive gear in the trans. The lowest gears you might want to use if you want fairly low rpm on the freeway but want to roast the tires a bit are 3.50 imo. The tire size is also a factor in determining the gear ratio. The z spec t5 has far better gear spacing than a standard t5 and is also a stronger trans.
