1965 v8 mustang yorke compressor vibration
Author Topic: 1965 v8 mustang yorke compressor vibration  (Read 7855 times)
Offline steve i
« on: March 29, 2013, 02:19:14 pm »
I have 65 convertible v8 d-code that I have fitted as close to possible original air conditioning with yorke compressor & under dash evaporator unit.Have had continuing problems with leaking compressor & have bitten the bullet & fitted a new compressor.My problem currently is bad vibration thru vehicle with air conditioning on.Have tried different amounts of R134 & different belt tensions but still have the problem.Has anybody else had this problem & have you been able to overcome it.I currently have the new compressor out & back to the supplier to be tested but have no anser yet
thanks steve i
Offline EXHAUSTED
  • Nearly retired
Re: 1965 v8 mustang yorke compressor vibration
« Reply #1 on: March 30, 2013, 08:13:42 pm »
You might find that the belt is causing the problem. The early engines had a modification with an extra tensioner added to it as in the later models.
Online peter9231
  • Name: Peter
  • Car: 66 convertible
« Reply #2 on: March 30, 2013, 08:45:40 pm »
The extra idler will assist but York compressors are common for vibration.
The later Australian fitted ones (Falcon) had a big inertia weight mounted on the rear of the clutch assy.
It didn't resolve the problem altogether but it did improve it.
Peter.
