302 Windsor help
Author Topic: 302 Windsor help  (Read 25344 times)
Offline shelby_mustro
  • Name: Ryan
302 Windsor help
« on: December 27, 2012, 09:44:53 pm »
Hi all.
I need help with my 302 Windsor. It's getting plenty of fuel it's got spark. I have tried both of the compression strokes tried two new dizzys and still can't get it to run!! Any ideas? Or is their someone on the Gold Coast willing to come round for beer money to help me out.
Thanks in advance.
1965 Ford mustang coupe
hipo 4bbl 347 windsor v8
t5 5 speed manual
4 wheel power assisted brakes
Other cars
1967 mustang coupe 289 c4 red
Offline Muzzy 66
Re: 302 Windsor help
« Reply #1 on: December 27, 2012, 09:53:32 pm »
was it running or is it new..?
Growing old is inevitable, growing up is optional.
66 Muzzy Coupe
  • Name: Ryan
« Reply #2 on: December 27, 2012, 10:34:31 pm »
I bought the motor second hand but have never seen it run before.
t5 5 speed manual
Other cars
« Reply #3 on: December 27, 2012, 10:38:48 pm »
I will come and have a look 4 you .pm your ph number .GLENN 70
  • Name: Ryan
« Reply #4 on: December 27, 2012, 11:09:55 pm »
Sweet ill take any help I can get.
t5 5 speed manual
Other cars
« Reply #5 on: December 27, 2012, 11:26:53 pm »
What part of the coast
Offline Muzzy 66
« Reply #6 on: December 28, 2012, 08:10:37 am »
possibly clevo firing order as a lot of windsor's are now days..???
66 Muzzy Coupe
Online peter9231
  • Name: Peter
  • Car: 66 convertible
« Reply #7 on: December 28, 2012, 08:32:36 am »
Hello,
Try taking the plugs out and putting one squirt of oil from an oil can in each cylinder.
I used to collect early Falcons and if they had been sitting for a long time this was the only way they would start.
It defies logic, they had spark,fuel and compression but refused to start.
When the oil was added away they would go.
Peter.
  • Name: Ryan
« Reply #8 on: December 28, 2012, 01:25:09 pm »
Thanks guys Glenn 70 sorted it out for me!!
t5 5 speed manual
Other cars
Offline mojocoops
« Reply #9 on: December 28, 2012, 03:29:51 pm »
What was the issue, out of curiosity?
« Reply #10 on: December 28, 2012, 06:21:02 pm »
He had the dissy one tooth out and 180 deg out  Simply fix i lifted the dissy out spun it around 180 reset and it fired up as soon as he hit the key . Happy now i hope .
Offline TimR67
« Reply #11 on: December 28, 2012, 07:07:35 pm »
Good Work Glenn70, Its good to see the Mustang Brotherhood alive and well
  • Name: Ryan
« Reply #12 on: December 29, 2012, 10:51:41 am »
Yep thanks guys. that saved me a lot of time. Just got the rest of the car to get back together now.
t5 5 speed manual
Other cars
  • Name: Ryan
« Reply #13 on: December 29, 2012, 05:23:02 pm »
Glenn I may need your help again mate when the radiator comes in. I was mucking about with the timing today because it was reving too hard so I decreased the dizzy a bit. Sounded better but now it won't start again. I turned it back to where it was but still nothing.
t5 5 speed manual
Other cars
« Reply #14 on: December 29, 2012, 06:49:50 pm »
No worries just let me know and i will come over .
Offline Blue Oval
« Reply #15 on: December 29, 2012, 08:04:21 pm »
Glenn 70.. you are what all club members sould be. Well done mate !
Cheers  :cheers:
 1966 GT Coupe. AFR 185 heads, Hyd Roller cam.  1/4 mile 11.21 sec @123mph
  • Name: Ryan
« Reply #16 on: January 07, 2013, 11:43:19 pm »
Alright moving on now.... Car is running but can't seem to stop the motor from over heating I have blown of the radiatior hose twice now. could it be the radiatior cap they supplied me is the wrong one? I'm running a Thurmo fan on the inside of the engine bay. (Side of the motor) should the fan be running through the radiatior or be pushing air towards the motor? Is their anything else I can do to stop over heating?
I know timing Is still a little bit out but wouldn't be that much to cause it.
t5 5 speed manual
Other cars
« Reply #17 on: January 08, 2013, 09:10:20 am »
Ryan what am i going to do with you .....Timing wont be the problem at the moment ,I will come back over and we will check a few things ,give me a call .Themostat not opening ,head gasket blown and maybe  on wrong ,inlet gaskets blocking water jackets .
« Reply #18 on: January 10, 2013, 10:49:42 am »
Ryan if you have cap off and let it run does it bubble in the rad when you hold some revs on it? that will be a head gasket. You can get the water tested to see if there is exhuast in it. If you are blowing hoses off I think you have an issue with a head leak. But in real terms it should pop the cap before a hose. Is this engine that has been hot a few times, that had the scratched bores?
  • Name: Ryan
« Reply #19 on: January 11, 2013, 12:10:13 am »
Nar that's not the motor ha I turned that old one into a coffee table haha.... yes it does that I'm sure it's the head gasket. Rev it the coolant goes from green to gray and bubbles out fommy just gets hot all the time. I'll replace the heads on it with reco ones. This is just a get me by motor untill I can fund my 347.
t5 5 speed manual
Other cars
« Reply #20 on: January 11, 2013, 08:55:17 am »
So it's not getting hot to start with if this is the case, it just blows the water out due to a compression leak then it getts hot.
  • Name: Ryan
« Reply #21 on: January 11, 2013, 09:53:33 am »
Yes but I still will need to replace the head gasket right?
t5 5 speed manual
Other cars
« Reply #22 on: January 11, 2013, 10:10:44 am »
With out looking at it, It sounds to me like there is an issue with the heads/gaskets. You could get the water tested to be sure.
  • Name: Ryan
« Reply #23 on: January 11, 2013, 09:26:57 pm »
Shaun I have already done the drivers side so I know the rh side would be it
t5 5 speed manual
Other cars
« Reply #24 on: January 12, 2013, 02:00:27 pm »
Hey Ryan did you do the gasket before you put the motor in? you didn't put it on backward did you?
