Street Fighter 1966 Ford Mustang, Part 7
Author Topic: Street Fighter 1966 Ford Mustang, Part 7  (Read 9535 times)
CPU
  • Guest
CPU
« on: August 10, 2010, 12:46:43 pm »
1966 Ford Mustang Gets Rear Suspension- Fantastic Four-Link
Transform The Handling Of Your Early Mustang With A Four-Bar Coilover Rear Suspension From Total Control.
From the June, 2009 issue of Popular Hot Rodding
By Liz Miles
Photography by Liz Miles
[align=center]
[/align]
This '66 Mustang is being transformed from an all-original six-cylinder cruiser, to a dual-purpose, road-race street car. To that end, we've replaced the factory drum brakes in the front with Wilwood 13-inch rotors and six-piston calipers, upgraded to a Wilwood dual-reservoir master cylinder, and converted the box-and-linkage-style steering to Total Control Product's rack-and-pinion steering, to get it closer to our goal.
Last month, we put together a Ford 9-inch rearend at Currie Enterprises to replace the one-legged, drum-brake 8-inch factory rearend, which is weaker than the stronger '67-up 8-inch. We took Chassisworks Fab9 housing and stuffed it with a Detroit TrueTrac gear-type posi, 3.50 gears, Wilwood 13-inch brakes, and Currie 31-spline axles. You can order the Fab9 housing to fit many models, or you can get a kit to retrofit your current housing to work with their suspension. This may sound like overkill for the six-cylinder currently residing between the fenders, but it is a necessary step for the 560-plus horsepower 427ci Windsor waiting in the wings. This direct-fit housing was built specially by Chassisworks to use a triangulated four-link coilover setup from Chassisworks' Total Control Products (TCP) division. TCP's canted four-bar, otherwise known as a triangulated four-link, is a street-friendly rear suspension that's built with enough adjustment for competitive racing.
The four-bar setup uses upper and lower links that have multiple mounting positions to adjust chassis antisquat and to optimize vehicle handling. Upper links are adjustable to set pinion angle and suspension preload if needed. The g-Link's lower arms are also adjustable for wheelbase variations and precise housing alignment. This kind of adjustment couldn't be possible with a traditional leaf-spring setup. This system can be used with either coilover or air springs. We chose to use the coilovers for their simple design and adjustability. With a choice of three upper and four lower mounting holes, ride height can be altered without adjusting the preload on the spring. As with all coilover systems, being able to corner weight the car with minor adjustments can yield huge improvements at the track.
We had a choice of three different lower links, a non-adjustable link with poly bushings for smooth and quiet operation, an adjustable steel link with pivot balls at either end for maximum strength and tuneability, and billet aluminum links for weight savings--which is what we chose here. The upper links come with poly or pivot ball ends (which we chose) and both styles are adjustable.
To go with our new suspension, we opted to use TCP's adjustable-rate 5/8-inch sway bar. It has three mounting points at the end of the bar to adjust its effectiveness. Our Mustang didn't come with a rear sway bar from the factory, but I'm a big believer in them, so that's the way we're going here. The sway bar mounting points are incorporated into TCP's direct-fit housing and frame brackets, which make it an easy bolt-on.
The installation process was incredibly easy. In most cases, the words "bolt-in" or "direct-fit" have very little meaning, but these TCP components actually fit. The best advice we can give you before you start this installation is to actually read everything first, and look at all the parts. Make sure you have all the tools you need to finish the project before you begin, including a MIG welder.
Four-Link Ford Fix
Total Control Products offers two different four-link rear suspensions for early Mustangs, the g-Bar and g-Link; both systems convert the leaf-spring setup in '64-70 Mustangs (and '67-70 Mercury Cougars) to a triangulated (or canted) four-link. Both systems use a bolt-in cradle to simplify installation and guarantee proper geometry, however, the difference in nomenclature is due to the g-Link's re-buildable pivot-ball bearing housings (similar in concept to a Heim joint) for its control arm joints, while the g-Bar employs a street-friendly poly bushing. The one thing that's important to remember is that the leaf spring is completely eliminated in both. This does several good things, like decouple the suspension travel from the pinion angle, and eliminate axle wrap and wheel hop associated with leaf springs. Moreover, spring rate and ride height are fully adjustable (up to 4.5 inches of adjustability), and a wide choice of coilovers are available, from single-adjustable VariShocks, to double-adjustables, and even Ride Tech's ShockWave air spring/shock combos.
[align=center]
We won't go into a lot of detail on how to get the original equipment out, but keep in mind you'll have to disconnect the driveshaft, brake lines, exhaust, shocks, and leaf springs. We removed the fuel line just to be safe, and plugged the rubber line from the tank with an old spark plug.
[/align]
Within the g-Link rear suspension family, there are additional options, such as an upgrade to billet lower control arms. Customers can choose to use their own rearend housing (either 8- or 9-inch, so long as the axle tubes are a minimum of 213/16-inch diameter), or use one of Alston's bomb-proof Fab9 housings, as we're doing here with the Street Fighter Mustang. Customers electing to use their own 8-inch housing can purchase Alston's upper control arm weld fixture, which precisely places the upper control arm mount so that it may be welded correctly. (A big plus in our book since we've had to do the exact same operation without such a fixture when we converted to a four-link on our '76 Camaro project car.) We'll also mention parenthetically that the stock 8-inch rear is super safe to about 350 hp when the stronger '67-up carrier assembly is used.
One other nice Total Control touch is the flexibility of shock mounting geometry the g-Bar and g-Link provide. This allows the user to tune the leverage ratio on the coilover for a maximum range of handling characteristics. Those opting for coilovers also have a large selection of spring rates to choose from, ranging from 110 lb/in of rate, up to 300 lb/in, with eight choices in all. One trick option you'll want to look hard at is the spring seat thrust bearing, which seats the bottom of the coil spring in a sealed Torrington bearing. This makes changing the ride height an effortless affair, as there's almost no turning resistance once the spring seat is unlocked.
So what's all this gonna cost you? We shelled out $2,918 for the max-effort combo, but you can get into a basic g-Bar system, using your own rearend, and equipping it with single-adjustable VariShock coilovers, for about $1,739. If you've got a serious street Mustang or Cougar project going together, you may already familiar with Total Control's constellation of front suspension parts. The g-Bar and g-Link are a great complement to these pieces, and as a whole, bring Ford's 40-year-old econocar suspension into the 21st century, and then some.--Johnny Hunkins
[align=center]
[/align]
WHERE THE MONEY WENT
TCP G-Link kit   $2,598
TCP sway bar   $289
TCP spanner wrench   $31
Total   $2,918
STREET FIGHTER MUSTANG THE COST SO FAR
'66 Mustang 6-cyl. coupe   $3,800
Battery replacement and relocation (11/08)   $299.00
Radiator and fans (12/08)   $1,398.12
Spindles, front brakes, wheels, and tires (1/09)   $3,067.04
Trunk rehab and tool box (2/09)   $40.48
Rack and pinion steering, column, and steering wheel (4/09)   $3,012.00
9-inch rear and brakes (5/09)   $4,631.02
Rear suspension (current)   $2,918.00
Total   $19,165.66
[align=center]
Once the metal is clean, put the brackets and cradle back up into the car. Bolt it in loosely where the shocks originally mounted to the body. While supporting the frame brackets with a C-clamp, measure to make sure the cradle and brackets are in square
The frame brackets have two holes in them that you will need to continue though the frame rail. In addition to the weld, the brackets attach with a square-bent U-bolt that you will push though one hole to come out the other
Double-check that the cradle and brackets are still square, then tighten all mounting hardware. Now you're ready to weld the frame brackets onto the frame. I used a Lincoln SP-135 MIG welder that operates off your everyday 110 outlet. TCP instructs to stitch inch-long sections, leaving an inch gap between them.
Once the weld cools, paint the weld and other bare metal areas to keep them from rusting. I used Dupli-Color's rubberized undercoating, and masked the area with a piece of cardboard.
Bolt the lower link in where the front of the leaf spring was originally mounted. The upper link can also go in at this time. Often the bolts only want to fit one way, but if you have a choice, we suggest being as consistent as possible, facing the heads of the bolts either inward or outward for a clean look.
Now it's time to bring in the rearend. Carefully jack the new rearend roughly into place, and bolt the links to it as the TCP
Bolt the coilovers in with the supplied brackets and hardware without the springs installed. Jack the rearend up, moving the suspension though its full range of travel to make sure there is no binding. If it looks OK, you can install the springs in the coilovers. TCP offers a spring compressor, but we were able to push down on the spring enough to install it.
We wanted to see where the ride height was before making any adjustments. The wheel fit beautifully in the wheelwell, however, without modification to the lip, it wasn't practical to leave it; we needed to raise the rear about inch
Once the car is close to its desired ride height, you can adjust the spring pre-load with TCP's spanner wrench. The adjuster has a ball that fits into a detent on the threaded section of the shock, so measuring the number of full and partial rotations is extremely easy. Make sure you finish your adjustment at one of these detents so the set screw doesn't damage the threads
The frame brackets come with threaded inserts to mount the chassis-side sway bar brackets. Before slipping the bushing over the sway bar, grease it with the supplied lube.
The end links are adjustable, so you can ensure there is no pre-load on the sway bar when the suspension is at rest. There are three dimples on the sway bar to choose from to give the bar more or less effect
Before you lower the car and walk away from the project, grease all of the Zerk fittings on the new suspension to help it last a long time. The rear suspension still needs some adjusting, and once the new front suspension is installed, we will be able fine-tune everything together.
[/align]
In the next issue they fit a Total Control Product's Coilover Suspension in the front end
Offline EXHAUSTED
  • Nearly retired
« Reply #1 on: August 10, 2010, 08:02:14 pm »
Installers phone number please.  She looks handy!!:rub:
Sorry I just can't help myself!!:rol:
CPU
  • Guest
CPU
« Reply #2 on: August 10, 2010, 08:04:09 pm »
Quote from: EXHAUSTED link=topic=11788.msg124864#msg124864
I found her first.... bugger off :lol:
PS
Hmmm, I can see a ranking name change coming on :bats:
Offline EXHAUSTED
  • Nearly retired
« Reply #3 on: August 10, 2010, 08:05:01 pm »
Quote from: CPU link=topic=11788.msg124866#msg124866
Awwwww come on mate   .....    share!!:smile01:
CPU
  • Guest
CPU
« Reply #4 on: August 10, 2010, 08:12:56 pm »
Quote from: EXHAUSTED link=topic=11788.msg124867#msg124867
Like your new Forum Ranking Name? :smile01:
God.... I just hijacked my own thread :banghead:
Offline EXHAUSTED
  • Nearly retired
« Reply #5 on: August 10, 2010, 08:22:52 pm »
It's good to have a laugh at the end of the day.
Cheers for that CPU ... I think:thud:
Offline jbrucem1
« Reply #6 on: August 10, 2010, 08:48:11 pm »
seems to be an ongoing trend with this car, why do they start to clean the underside (which is filthy) then stop and bolt in all this shiny flash new gear..maybe part 1 should have been clean prep and paint undercarriage - would make all the difference i think..
Offline Dyn4mic
    • http://dynamicstang.blogspot.com/
« Reply #7 on: August 10, 2010, 09:43:51 pm »
this is great cpu looking at changing mine to IRS
http://www.totalcontrolproducts.com/products.html
some great products and ideas for anyone else interested here goes next years tax :hammer:
thanks cpu
67' Coupe
