Front Drum Brake - Hub removal.
Author Topic: Front Drum Brake - Hub removal.  (Read 2245 times)
Offline 064 PNY
« on: July 26, 2010, 10:38:48 pm »
looking at replacing fromt drums and shoes, etc on a 64-1/2. Have removed drum previously by removing with entire hub. Is it normal for drum and hub to be "pressed" together or is this something that happens over time if the two have not been separated for some time? What is the best way to seperate hub from drum so can replace old drum with new on existing hub? Thanks.....
Offline mert
« Reply #1 on: July 27, 2010, 09:27:51 am »
You should not have to press the drum off the hub.
If it sat a long time they can corrode in place.  If the brakes are misadjusted they can bind if the pads are jammed against the drum.  If the pads are worn into the drum surface they can be "locked" in, the studs holding the pads to the shoe base can grind into the face effectively tounge-and-grooving the pads into the drum (assuming studded, not bonded pads).  Back off the pads as far as you can using the adjuster and you should be able to get them apart.
A few light raps with a rubber/plastic mallet can free some corroded bits, don't whack with a steel hammer you can crack the drum..
