Technical & General Discussion Area => Tech Torque Pre 1973 => Topic started by: 66ccode on June 28, 2005, 08:03:06 am
Can anyone tell me why my headlight flare from quite bright to a dim yellow when Im idling? Im hoping its just the voltage regulator??? If so, are they expensive/simple to replace?
Try your reg first. They are pretty cheap from Repco or similar auto parts stores, and identical to the more expensive replacement "Mustang" regs. Simple to replace, 2 bolts and plug it in. It's the 2 inch square black box located on the radiator support panel on the opposite side of the car from the battery. Good luck.
If that doesn't work you can upgrade your alternator to a new one but then you will have bypass the reg as they have a one built in.
I agree with Nassi and Pete.
Had the same problem, upgraded both Regulator and Alternator (some alternators have a built in reg as Herman mentioned )and problem solved.
The whole lot should cost under $200. (reco alternator and repco reg)
Best of luck 66ccode
Great, thanks for your help everyone, I'll give the regulator replacement a go on the weekend. I just had the alternator rebuilt, so I don't want to replace that. (don't you hate it when you go and get something done only to find that you should have gone a different direction.)
