Technical & General Discussion Area => Tech Torque Pre 1973 => Topic started by: convertable67 on May 08, 2006, 03:47:42 pm
Hi guys i am putting a procomp electric dissie into my 302c and was after a few hints. anyone got one?? my mustang has the starter relay on the fender and from what ican gather without getting into it just yet it may be more than just plug in two wires as per the box (no installation instructions included) As an old points man i ve yet to even work out how to time the thing, any help apprecatied
If you have never swapped a dizy on a v8 before, my advice would be get a mechanic to do it for you & watch & learn how its done.
You need to find top dead centre compression stroke on # 1 cylinder, remove old dizy, re fit replacement dizy & hopefully the oil pump drive is lined up, align #1 on cap & rotor while checking the position of the pickup / trigger coil as you tighten the base clamp, source correct electronic coil, check supply & cranking voltage to the + of the coil, etc..............
