Technical & General Discussion Area => Restomods => Topic started by: tired69 on November 05, 2019, 03:51:18 pm
Hi all
I remember on here some where somebody reshaped there tail light lens to the same shape as rear panel just wonder how that did it have searched but nothing came up
Another option are these
http://www.brightlight-customs.co.uk/1969.html
you mean like this??
Hi Lee
Did you make them yourself or buy them? They look fantastic.
thanks HRTZ65, Yep I made them myself
yeah there the ones
I've looked at bright light customs led kits etc thay don't have light diffusers .
how did you do yours.
ok I'll dig out some photos and try to explain how I did them, Not saying it's the best way, or even that they are street legal.
(there's my disclaimer..hahaha).
to start I cut the lens down to the step using a die grinder and small cutting disc
for a diffuser I used one from a florescent light and cut to suit, using a heat gun I softened the plastic to make it supple, then using a timber mould I made, used that to form the shape
used an acrylic glue to glue the diffusers to the cut lens, once set used the die grinder to shape the edges
picked up some 3mm red acrylic for the outer lens cut to size, ad again heated with a heat gun, pressed them in the timber mould, glued them to the diffusers, then again ground the edges to shape
didn't find a photo of the finished part on the bench just in the car, I'm happy with how they turned out . they don't have a reflector included so may not be street legal.
Hope that helps you out, they weren't too difficult to make just took a couple of weekends
That's really impressive. Not sure I could have done that, even with instructions.
Thanks very much for that I'll give it a crack doesent look to hard
cheers. :cheers:
No worries, have fun tinkering :grin: :grin:
Hi Lee
Did you use the existing chrome trim around each light and reshape it or did you fabricate something new?
yep that's just the original trim piece, I tried to keep things as easy as possible
Looks great!
How did you bend those?
s
didn't bend them, they are the original mouldingsā¦.
That's one very neat rear end. Very impressive.
