Technical & General Discussion Area => Mustang Chat Room => Topic started by: Andrew_Coyote on December 01, 2022, 07:03:52 am
Hi all
was wondering if anyone has done a top end rebuild if so what gaskets were used what brand and also if the head bolts were replaced please and thank you
Beat any brand of gasket is fine. Fel pro is the most common brand in the us. . I have never replaced head bolts. The originals are usually fine to reuse. . Tap the exhaust bolt holes to insure the exhaust bolts go in easily.
If you're replacing the exhaust manifold gaskets Remflex are hard to go past. I put some on mine a few years ago on Barnett's advice. I just put some Felpro rocker cover gaskets on and they seem pretty good, certainly solved my oil leak problem I had there.
I always use fuel pro gaskets . Buy a full set and it has everything you need and cost only a bit more than just the top end kit . Top end gasket has limited gaskets .
Felpro will do fine. They have been around since Noah was a boy so they are a proven OEM.
