What did you do for your Mustang today?
Author Topic: What did you do for your Mustang today?  (Read 655376 times)
Offline GT350H
Re: What did you do for your Mustang today?
« Reply #50 on: March 21, 2013, 08:11:02 am »
HELP PLEASE !!
I havent driven the mustang in over 3 weeks, so I thought I'd take it out for a bit.
Low and behold, 5 minutes into the trip and the shifter comes lose ( really lose ).
I got it home, but only just.
Ive got a 5speed T5 and my Hurst shifter keeps coming lose. Ive tried changing the bolts ( using allen key high grade atm ) and Im using loctite.
Any suggestions to stop them from rattling lose?
AKA Emberglo-66
Offline Ash
  • Name: Max Power
« Reply #51 on: March 21, 2013, 08:15:48 am »
Is there plenty of room under the boot where the bolts are, could you put a longer bolt in and a locking nut on the back?
Offline GT350H
« Reply #52 on: March 21, 2013, 09:11:14 am »
Have tried that and it continues to come lose.
AKA Emberglo-66
Offline Ash
  • Name: Max Power
« Reply #53 on: March 21, 2013, 09:14:37 am »
Must be some kind of clash in there then if even the locking nut comes undone. Was it a nylock nut that you used?
I removed a T5 shifter yesterday off a 97 EL. Still had the original bolts in place, no locking nut on the back and they were tight as hell.  Maybe the bolts you are using are the problem, try a lower grade bolt? Or even some standard Falcon ones?
I can add a photo of the standard Falcon gear if you are not familiar with them if you like.
Offline Mustangpaul
  • Look before you leap
« Reply #54 on: March 21, 2013, 12:39:40 pm »
A picture paints a thousand words. We have a Base Coat
Offline 66 Hertz
  • Web Editor
  • SA member #787 MOCSA
  • Name: Dale
« Reply #55 on: March 21, 2013, 01:07:36 pm »
GOOD NEWS MATE!............ :thumb:
Paint by IMAGE CLASSIC CARS
Offline RayAzza
  • MOCA NSW
  • Name: RAY
« Reply #56 on: March 21, 2013, 03:49:46 pm »
new front shocks going in.
./__ __ __ __ __\.
( ]]] __ O __ [[[ )
 \_o_ _____ _o_/
   |___|     |___|
Offline MU6TNG
  • Vic Member #2433
« Reply #57 on: March 21, 2013, 04:49:44 pm »
Removed radiator to repair a small leak from the auto cooling inlet, replaced inner and outer tie rods, idler arm and some new sway bar end links.
Ray
Offline Mustangpaul
« Reply #58 on: March 21, 2013, 04:56:44 pm »
HELP PLEASE !!
Unsure of exactly what set up it is but my brothers (panel beater and spray painter) always went with a lock nut in difficult situations. Tighten one nut and then slip another nut straight nut behind the first nut. Hope this helps.
Offline GT350H
« Reply #59 on: March 22, 2013, 08:08:25 am »
Might give that a go ( the lower grade bolt ).
Thanks Ash.
AKA Emberglo-66
Offline GT350H
« Reply #60 on: March 22, 2013, 08:10:14 am »
That would be ideal and I reckon it would work but not sure if I have the room to do that. I'll look at that option the next time I have to pull the boot cover off the shifter.
Thanks Paul.
AKA Emberglo-66
Offline Mustangpaul
« Reply #61 on: March 22, 2013, 12:32:19 pm »
Possibly a fiber washer may also help?, best to check for the original specs if you can track down a diagram
Offline Mattstang
  • MOCA NSW Member
  • Name: Matt
« Reply #62 on: March 22, 2013, 05:48:43 pm »
Gday Ray,
What shocks ya runnin??
Matt
Offline RayAzza
  • MOCA NSW
  • Name: RAY
« Reply #63 on: March 22, 2013, 10:57:11 pm »
Hey Matt
got a set of KYBs from Harry rides sweet now.
./__ __ __ __ __\.
( ]]] __ O __ [[[ )
 \_o_ _____ _o_/
   |___|     |___|
Offline Mattstang
  • MOCA NSW Member
  • Name: Matt
« Reply #64 on: March 22, 2013, 11:08:50 pm »
Hey Matt
Cool,
you will now be able to come along to Bodytech show & shine next month in style and comfort!
Matt  :thumb:
Offline RayAzza
  • MOCA NSW
  • Name: RAY
« Reply #65 on: March 23, 2013, 05:15:50 am »
LOL no can do Matt got a bucks night to attend  :smilies:
./__ __ __ __ __\.
( ]]] __ O __ [[[ )
 \_o_ _____ _o_/
   |___|     |___|
« Reply #66 on: March 23, 2013, 08:04:51 pm »
Cleaned up the engine bay a bit more today by painting a couple of more brackets black and replaced the radiator overflow hose with a new black one.
Offline Ash
  • Name: Max Power
« Reply #67 on: March 23, 2013, 08:17:26 pm »
Wasn't today but during the week the wife said the brake pedal went to the floor on the 66. Went to swap out to a new M/C and I don't think the brake lines had been touched in decades. My spanner set was not going to do anything but round it over. Luckily 10 minutes before I had just been up the steet dropping my kids off to school and I saw a Snap On truck at the local smash repairs. Shot up to him, $40.90 later, the most I have ever paid for a single small spanner, I walked out with a flare nut spanner that did the job in seconds and caused no damage. Man, am I glad the Snap On guy was in town as there was no way that job was getting done with out damaging something and waiting a week or more for a new part to turn up. The brakes work great now, even for manual 6cyl drums  :thumb:
Offline scollist
  • 65FB, 2017 GT
  • Name: Shane
« Reply #68 on: March 23, 2013, 10:01:18 pm »
New set of KYB Gas-Adjust shocks for the rear of my 65FB.  Definite improvement in helping fix the tyre rubbing on my 15x7 Cragars, but still a little bit of rubbing on severe bumps.  Slight rolling of guards may be next to finally fix the prob.
Also tested out the fuel guage - currently shows only just over half when it is fully filled. Earthing the gauge showed it go way past full, so I believe that a new sender unit is in order.  That'll be in the next couple of months.
Offline MU6TNG
  • Vic Member #2433
« Reply #69 on: March 24, 2013, 08:56:18 pm »
Greased all tie rods and ball joints changed oil filter and gave her some HPR30.
Offline Mattstang
  • MOCA NSW Member
  • Name: Matt
« Reply #70 on: March 24, 2013, 09:17:59 pm »
Jack, nothing, zero , zilch
Missus arrived back this afternoon from a 4 day trip to outlaws place up at Coffs, I was looking very busy doing garden maintenance and all other mundane tasks around the house that I had been putting off all week because every other day she was away I was driving the Mustang and loving it!!
Offline Raven
« Reply #71 on: March 24, 2013, 10:48:14 pm »
Worked all day on mine. Still looks like I've done nothing!
R_Beckhaus
  • Guest
R_Beckhaus
« Reply #72 on: March 25, 2013, 05:12:46 pm »
Bugger all
Offline Mustangpaul
« Reply #73 on: March 25, 2013, 08:33:27 pm »
Nearly painted now
« Last Edit: March 25, 2013, 08:36:27 pm by Mustangpaul »
Offline Gretschem
« Reply #74 on: March 25, 2013, 09:06:49 pm »
Pulled the engine out.
