All the boys are working back tonight in an attempt to keep on schedule.
Progress can sometimes be slow, because every part must be thoroughly cleaned, sometimes painted or polished up or replaced. Here are a couple of examples -
Parking Brake mechanism - Brad had been cleaning and painting it a few weeks back, but we found out that replacement mechanisms are now available. The chrome on the old one was a bit pitted, so we went with the newie -
Power Steering Pump is OK so we cleaned it up and painted it -
And so on, and so on.
Happy to see that our problem with the Harmonic Balancer has been overcome. Belts line up very well now and have been fitted -
Brad was pleased to be at the stage of fitting the Radiator this arvo -
Jeremy has fitted the door and quarter glass -
Then he fitted the rubber door seals. These are glued on and masking tape is used to hold them in position until the glue dries -
Next it was time to fit the rear spoiler -
Test fit -
Finished -
In the meantime Luke was helping Ron to paint the bottom of his Mach1 which goes for registration inspection on Monday -
When i left work this arvo they were busy fitting the front guards and headlight buckets. Think MachAttack was correct. There are going to be a few late nights coming up.
Rocket.
