Technical & General Discussion Area => Technical - General => Topic started by: 65gtfasty on July 19, 2017, 12:43:06 pm
Hey
Just wondering what peoples thoughts are on front sway bars foe 65 fastback with twin paxtoned 302 in it are , the Scott drake 1" complete package is $250ish- is tgis good value or rubbish like most repro stuff is .
The car will be used mostly on the street with the occasional track run .
Any opinions are greatly appreciated.
Rhys
Try the Whiteline sway bar.
http://www.whiteline.com.au/catalog/Sway-Bars-Anti-Roll-Bars/FORD/MUSTANG/
White line make them from the Selby's tools which are also the Pedders. No biger than 1" Mustang's piss weak and a big sway bar flexes the front structure
Thanks for that info!
Just wondering if anyone has had fitment issue with the selby sway bar seems too wide (have read elsewhere 65/66 eye to eye measurement is 965mm and selby(67 onwards is 1025mm )
...with the occasional track run .
What EXACTLY does this mean?
A suspension that works well on a road race track will knock your fillings out on the street.
You should also stiffen the body with sub frame connectors and a shock tower brace and rallye bar etc if you don't already have these.
