Technical & General Discussion Area => Restomods => Topic started by: tired69 on October 15, 2018, 05:22:08 pm
Hi all.
has any body out there used falcon fire wall and all parts required including dash etc and put in to a early model stang I was wondering if you could take out whole fire wall and cut and fit it in instead of chopping a mustang in to a hundred pieces and going though all that drama.
just curious.
Look up "Steering conversion" Mustang chat room June 3 2018, may be something there of help..,
Hi all.
just curious.
Not really how you do it. Though can buy new RHD firewalls from mustang auto parts in Brisbane but they are just flat and you cant use Falcon pedals etc as easily , nor fit an AC unit. As for the original one you just leave the center and make new ends.
Frankenstang has the dash and all running gear from an ED Falcon in it(https://preview.ibb.co/hsw3gL/100-0343-2017-01-13-06-51-42-UTC.jpg)
I was told about 15 years ago by someone who did conversions that a firewall out of a xa/xb/xc with about 100mm cut out of the middle will do the job. Maybe worth checking and measuring.
Stormin
Ive done couple of RHD swaps and always made my own stuff, but you can buy it all new if you want.
https://mustangautoparts.com.au/collections/mustang-sheet-metal/products/firewall-rhd-67-68
https://mustangautoparts.com.au/collections/mustang-sheet-metal/products/cowl-panel-upper-67-rh-drive
https://mustangautoparts.com.au/collections/mustang-sheet-metal/products/cowl-panel-lower-67-rh-drive
https://mustangautoparts.com.au/collections/mustang-sheet-metal/products/dash-panel-sheet-metal-67-68-rhd
Does anyone know how to get in touch with "Tired69"?
I've sent him a message about a RHD Firewall i have that he might be able to use.
Wanted to give him first look at it before i put it up on Classifieds.
Steve
