So what you are saying i think is the engine stops sometimes ,but not when you are driving around ,its mainly when you are ,lets say stopped but engine running ,then if you turn your headlights on, or some power usage the engine dies .If it has an electronic dissy fitted the coil has not been changed to a 12v and maybe still running a 9v coil .If so when revs are very low and you use any power even brake lights the engine will cut out .Is that what you are saying .
