Yes 67 will work, they are just selling you refrubed XF stuff for the front as far I'm aware. They don't really need rear disc's for normal use. You could do the same yourself with a set of XY- XF stubs and calipers from the wreckers, they will need a frensh up of course and some hoses etc. XY on, stubs, disc'c calipers are in my opinion the best all round option on these 67 on cars.
These are what GT falcons used. XY XA, early XB use smaller bearing hubs, if you want to run factory styled wheels etc you need these. If you get a set from the wreckers, a new set of standard rotors are about $35 each, seal kitts are about $15 per caliper, hopefully the pistons are alright, if not allow for these, Pads any where from $28 to what depending on what you want, again you can buy drilled /slotted rotors etc as well. some custom hoses about $40 each. You will need to use falcon outer tie rod ends. I don't consider the RRS stuff, I don't see the value in it really.
