finally done
Author Topic: finally done  (Read 7420 times)
Offline 2+266
finally done
« on: May 27, 2008, 08:22:12 pm »
well after 4years the stang is done,passed the regency park inspection today and am on full rego,now for some fun!:+:+:+:+:a:a:a:a pm me if you want the good bad and ugly about the inspection:(
Offline nassi
finally done
« Reply #1 on: May 27, 2008, 08:32:39 pm »
Congratulations ;+
66 Mustang covertible
01 XR8 ute (black)
01 XR8 ute (red)
56 F100
Offline shopony
finally done
« Reply #2 on: May 27, 2008, 10:01:29 pm »
Congratulatioms 2+266.  Now you will know what it is like to spend 4 years and $$$$$$$$$$ building your dream car and then have  Adelaide drivers sit 2 feet off your newly chromed back bumper.
Hope to see you on the road !!!!
Offline 2+266
finally done
« Reply #3 on: May 28, 2008, 07:00:59 pm »
thanks nassi , showpony i was peaking last night after the inspection on the way home when i was ridden like a donkey all the way back to my place!,if anyone has gone through regency in the past  couple of years please pm me as there is an issue with an inspector that i would like to clear up.thanks
Offline evan
finally done
« Reply #4 on: May 28, 2008, 07:27:00 pm »
You can't tell us it's finished & NOT post photos!!!:*
Congratulations. I'm dreaming of the day I can make a similar post! ;]
Evan.
Offline 2+266
finally done
« Reply #5 on: May 28, 2008, 09:50:36 pm »
thanks ev,will post some pics soon,went for a drive last night and the headlights started cutting in and out and the dash lights went out only after 5 minutes of driving:_ guess i'm up for a new switch!!!! fuses and grounds are fine.more dollars,bugger!!!!
Offline Bumblebee
finally done
« Reply #6 on: May 29, 2008, 02:20:12 pm »
Well done 2+266,
I had a similar problem when I first had my car with blinking headlights, turns out that halogens were installed without relays.  I had them installed and the transformation in lighting was fantastic, and the blinking stoprd too.  You need a decent electricion to make sure all the wiring is right, including the dip switch.
There's a great 'how to' article in mustang monthly on line that gives you a good heads up.
Many happy years of driving to you.
Cheers Bee
Cheers Bee
Offline 2+266
finally done
« Reply #7 on: May 29, 2008, 05:17:43 pm »
:( thanks bee,i installed 100 watt standard headlights so i dont have the halogen problem,started her up last night with headlights ablaze and tested it for 35 minutes and they didnt cut out once!!!!! (the car is posessed!!) i'll have to stick my hand in my pocket once again i think!!
Offline rene.pilat
finally done
« Reply #8 on: May 30, 2008, 02:37:14 pm »
Congrats Clinton. I look forward to checking the car out at the next outing.
Regards,
René
Offline 2+266
finally done
« Reply #9 on: June 01, 2008, 09:08:36 pm »
had my first real drive today,what a treat,not entirely happy with the gearbox ,anyone recommend a repairer?whiny in third and when i drop back to 2nd loud spinning noise comes from the box,like the bottoms going to fall out of it! any suggestions?
