C4 Neutral/Park switch
Author Topic: C4 Neutral/Park switch  (Read 634 times)
Offline Mylittlepony1966
  • Name: Kevin
  • Car: 66 coupe
« on: May 19, 2024, 07:52:28 am »
I pulled my 66 instrument  cluster out last week to run a new ignition  wire. I fixed that problem & created another. Now it will start in any gear. Coincidence C4 switch buggered or pulled a wire off somewhere???. I'm thinking if I pulled a wire off it would not start in park or neutral.
Was working perfectly  prior.
I'm all ears...
« Last Edit: May 19, 2024, 07:56:09 am by Mylittlepony1966 »
Online Aussie-67
  • Name: Tony
  • Car: 67 Mustang Coupe
Re: C4 Neutral/Park switch
« Reply #1 on: May 19, 2024, 12:22:16 pm »
Is the switch on the box ok?
  • Name: Kevin
  • Car: 66 coupe
« Reply #2 on: May 19, 2024, 03:12:04 pm »
It was, I haven't tested it yet; however,  sussed on it now.
Online Aussie-67
  • Name: Tony
« Reply #3 on: May 19, 2024, 04:21:53 pm »
So what was the problem ?
  • Name: Kevin
  • Car: 66 coupe
« Reply #4 on: May 19, 2024, 05:48:26 pm »
Starts in all gears. Haven't  checked tye switch yet. Don't know what the problem  was/is Aussie-67
Online Aussie-67
  • Name: Tony
« Reply #5 on: May 19, 2024, 06:02:04 pm »
Ok sorry misread your comment.  Thougt you sussed it/ fixed it.  If the wiring is ok  I would check the switch.
