Distributor for a 302W stroked 347
trentsiddharta:
The timing is advanced and it is pinging. If it's not advanced it dies. My 'mechanic' indicated the dizzie but also said that it needs a 351 dizzie, which isn't obviously correct.
When it was stock 302 it had no overheating issue since putting in a large core radiator and fans.
GLENN 70:
It can be a lot of things . Your timing should be around 12 to 18 deg initial with the vacuum advance blocked . The total timing should be 32 deg at around 3,000 rpm . Getting these numbers with a stock distributor won’t work . All this depends on the engine mods . More info please ,what carb and jetting , intake manifold ,heads ,cam and compression .
trentsiddharta:
Thanks Glenn (and everyone) I really appreciate this.
I'm 2% of a mechanic and have been taking advice from my current/soon to be previous mechanic, so my knowledge isn't exhaustive.
Carb - Factory 2-barrel. No choke (doesn't help)
Manifold - Factory
Cam - Steel roller 1.5
Heads - Original factory. Machined. New hardened valve seats.
Compression - will need to find out.
Distributor - old school Autolite
The distributor needs the gear swapped for melonized to suit the cam, so I considered a new on altogether.
I'm also looking to replace the carb with the same but an electric choke.
GEOFF289:
--- Quote from: trentsiddharta on March 01, 2024, 10:54:06 am ---
Manifold - Factory
--- End quote ---
It's a 347 but has a 2 barrel carb?
trentsiddharta:
Yes. I know. Doesn't seem right.
4-barrel would be better but from the perspective of it being a second car that my wife drives, it's unnecessary. Cost is also a factor.
Happy wife...
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
