Helllppp btr behind 347
Author Topic: Helllppp btr behind 347  (Read 2862 times)
Offline Wldhrse
  • Name: Brad
  • Car: 1966 coupe
« on: February 15, 2023, 01:00:25 am »
This may get very long winded...
But I have been given the bum steer by 'pros' since I started my built and I still can't get it fixed.
Every thing I read leads me to I've done everything wrong wasted alot of money and time and I may aswell torch the whole car...
I had a gearbox out of an el falcon (which from what I read is the hardest to work with because of the computers)
We have it in. And sometimes it works..but somewhere there's a glitch and overdrive drops out and the speedo bounces irratically.
But today the worst has happened...it wanted to just stay in first...
I'm not sure if it's electronic or if the box has let go somehow.
Are there any wizards in perth that have gone done this road or close to and can finally give me some correct answers or even better fix it for me.
I am litterally about to just torch what is such a fantastic car but it's driven me mental.
« Last Edit: February 15, 2023, 01:04:49 am by Wldhrse »
Offline peter9231
  • Name: Peter
  • Car: 66 convertible
Re: Helllppp btr behind 347
« Reply #1 on: February 15, 2023, 03:26:14 am »
What gearbox are you using?
Assume you are talking about a BTR?
Are you using a standalone ECU for it ?
Are you using all genuine sensors - throttle and speed?
Have you fitted a pull up resistor in the speed sensor wiring?
Peter.
Offline Wldhrse
  • Name: Brad
  • Car: 1966 coupe
« Reply #2 on: February 15, 2023, 08:30:13 am »
I really can't answer these questions properly...hense why I'm really looking for a local wizard to have alook over everything.
I've sent you a pm aswell. Cheers
Offline peter9231
  • Name: Peter
« Reply #3 on: February 15, 2023, 09:16:14 am »
Shiftkits Australia (in Perth) speak to Jamie.
Offline Wldhrse
  • Name: Brad
  • Car: 1966 coupe
« Reply #4 on: February 15, 2023, 09:17:23 am »
Offline Reborn67
  • Name: Andrew
  • Car: 67 Hardtop
« Reply #5 on: February 15, 2023, 08:50:43 pm »
How do you fit a shaker under a non cutout bonnet.? Or is it just an illusion of the photo.?
Curious..,
Offline Wldhrse
  • Name: Brad
  • Car: 1966 coupe
« Reply #6 on: February 15, 2023, 08:59:45 pm »
I found a spare bonnet to cut...and we made the shaker fit :)
