disc brakes et alia
Started by fredm666, February 01, 2023, 01:46:51 PM
Previous topic - Next topic
fredm666
G'day all!
I recently purchased a 1955 Ford Customline, and would like to pick your brain on disc brakes.
Do you think I can fit a disc brake kit for an early Mustang or Falcon in my Customline? Wheels are 15in.
Next thing is an under-dash A/C system, do you have anything to recommend? I'm not looking to keep originality, just some comfort when driving in summer and nothing big.
p.s. yes, I know it is a Mustang forum, but I still own my '64 D-code, so...  :smile01:
fred
GEOFF289
Not cheap but this would sort you out on the braking front.
https://www.rodshop.com.au/ford-disc-hq-cal-to-1949-1955-ford
Classic Auto Air has an AC kit for a '55 Fairlane, which is what a Cusso was in the US. Might be some issues with a RHD drive car but probably not too tricky to overcome.
https://www.classicautoair.com/shop/complete-ac-systems/1955-ford-fairlane-air-conditioning-system/
fredm666
Quote from: GEOFF289 on February 01, 2023, 04:01:26 PM
Thanks Geoff.
to the rodshop kit I need to add discs, calipers, brake booster and master cylinder.
regarding the AC, I saw the same kit on an Australian website and think it was around AU$2,500. The only issue is the compressor bracket, that might not fit with original exhaust pipe (in the engine bay).
fred
fredm666
I was wrong, that kit is AU$3,890 on the website I saw...
fred
jiffy
Quote from: fredm666 on February 01, 2023, 04:15:58 PM
Thanks Geoff.
I bought their '63 Galaxie kit late last year - hope to be fitting it mid-year this year.
Black '63.5 Galaxie 4SPD fastback (422chp/
493 clbft.)
fredm666
I received a quote for the disc brake conversion kit (including master cylinder and booster) from an Aussie company, kit apparently made by MP Brakes in the US. Price is $2,720, do you think it is a good price?
It might be this one with master cylinder and booster: https://www.mpbrakes.com/pc_product_detail.asp?key=687755395143474DA42D61C5F3C22A19&catid=5154504AC39C44DEA82714E2BF275B1D
The same company provided a quote also for an underdash AC system, different from the one in the other message, and similar to a '64-'66 Mustang aircon unit. Price is $2,729 all included (compressor bracket, compressor, condenser, etc.).
fred
GEOFF289
I haven't actually checked but my immediate reaction is that you should be able to do the brakes for less than that with the Rodshop kit and readily available local calipers, rotors, booster and master cylinder. Or somewhere like Hoppers Stoppers down here would be worth an enquiry. They are well regarded.
https://hoppers.com.au/tech-info/information-sheets-customline/
I reckon most of the under dash aircon kits from outfits like Classicautoair or Vintage Air are the same for all cars with just the bracketry being car specific. The compressor, condensor, evaporator, drier etc. will be universal.
fredm666
doing a quick calculation: Rodshop kit is $495, a decent master cylinder plus booster is $700/1000, disc and calipers $1500 (Wilwood on Rodshop website), plus some extra for hoses and fittings and maybe bearings.
I can probably find a cheaper disc+caliper, maybe around $1000?
It seems easy to get to $2500/2800.
thanks for the Hoppers Stoppers contact, I will check them out.
fred
GEOFF289
I guess if you want Wilwood stuff it will run to that sort of money but a quick bit of googling suggests to me that you could get the components for a lot less than those figures. I reckon $1,500-1,700 all up including the Rodshop kit.
fredm666
Quote from: GEOFF289 on February 03, 2023, 01:16:21 PM
You are probably right, I will need to start a serious search.
I don't really want Wilwood, or any super expensive brand, because honestly I don't need it (even though it would be nice to have). I can see booster and master cylinder at $200/250, but I'm wondering the quality they might have.
I checked Hopper Stoppers and their rotors+calipers are the same price as Wilwood.
fred
fredm666
I just checked few shops around Perth, including Supercheap/Repco, and this is what's coming up:
- Calipers $270+,
- Rotors starting at $80 to $220+ each (brand DBA, Bosch or similar),
- Booster $400+ (it's possible to find something slightly cheaper),
- Master Cylinder plus proportioning valve $300+,
- Hoses $70+.
Of course I still need to check if those rotors and calipers will fit my car.
the search continues  :grin:
fred
jiffy
493 clbft.)
fredm666
fred
jiffy
I bought it from the US, and had it shipped in. Shipping was $300AU
493 clbft.)
fredm666
Quote from: jiffy on February 04, 2023, 01:38:32 PM
that's not bad
fred
fredm666
I ended up buying the MP Brakes conversion kit and installed end last year.
It's a great kit, the Cusso brakes like a new car. If you need a disc brake conversion, I recommend looking at that brand.
The only issue was fitting the original factory wheels. They didn't fit by 5mm, as caliper was rubbing on the rim...
Same size but modern rim, no problem at all; at least I was able to keep the tyres.
fred
pmb0186
Hi,
I have played the air condition game.
Story.
I bought a complete under dash unit from a 66 supposedly a working when removed.........not
I installed it into a RHD car after changing the seals in the compressor, new hoses, new dryer, replaced missing parts, new Tx valve, flush, new oil and gas cost around $3500.00.
It worked for a few year before the compressor leaked again, after resealing and more gas it lasted another year.
Since I have changed the compressor to a sanden compressor.
What I learned if I did it again.
I would have bought the head unit only and from the start install new sanden compressor, condenser and modern dryer. I would have saved money any less grey hair.
pmb0186
Further to forgot cooling upgrades, fan shroud and 5 blade fan
