Vibration hard acceleration at 80-100km
Author Topic: Vibration hard acceleration at 80-100km  (Read 7286 times)
Offline FickleLife
« on: July 24, 2022, 05:04:56 am »
I was accelerating hard in my 66 from 50kmh to 100kmh and experienced quite a bit of vibration at about 80-90kmh when foot to the floor. Backed off and the vibration stopped - it feels fine lower revs but what would the cause be? Probably need to balance the tail shaft.
Does anyone have any suggestions for what it could be and if it is tails shaft balancing, any recommendations in SE suburbs melbourne? Thanks!
Offline Clubman7
  • Cruising.
  • Name: Brett
  • Car: 1966 coupe, 2016 GT.
Re: Vibration hard acceleration at 80-100km
« Reply #1 on: July 24, 2022, 08:45:10 am »
Universal joints could be worn out.
Mechanic should be able to figure it out.
Tailshaft could be checked.
There is GJ drivelines in Keysborough or Hardy Spicer in Dandenong.
« Reply #2 on: July 24, 2022, 10:40:22 am »
Should only be a uni joint  check the gear box mount too . . Or if your rear springs are shot ,they might be causing the pinion angel to go out .
« Last Edit: July 24, 2022, 09:14:13 pm by GLENN 70 »
Offline pmb0186
  • Name: PETE
  • Car: 66 MUSTANG
« Reply #3 on: July 24, 2022, 09:07:10 pm »
agree uni joint.
if the trans/ gearbox is leaking look at the yoke and bush.
does anyone remember laughter
Offline 67 blue
« Reply #4 on: August 05, 2022, 06:01:50 pm »
I've had the vibrations happen to me at 80 - 90 kmh. Looked into every thing that it could possibly be, and turned out to be a steel rim out of wack. Had to replace the rim.
