Hey Mel, welcome to the forum,
Of course it depends on you situation, Bank account etc.
If you going to such a large job consider going disc brake rear.
Ford Explorer brake package is very popular, they are disc brake with drum park brake.
This is what i have, in detail!
DIFFERENTIAL.
Ford 9" large bearing (new type) Differential.
Differential markings - Standard 9" case should be C7AW-E.
Large bearing (New Type) known as the Torino bearing or " Set 20".
Differential ratio - 3.25:1
Strange Auburn Pro Series Differential 9" Ford With 31 Spline Axles.
Currie axles CE2020T
PARK BRAKE SHOES.
Ford Explorer UN UP UQ US 1996-2001
Minor park brake shoe 3218
Abex 6068-gg
Ford Original 6W1Z-2N712-A
Fitted Tora brand N1774 / FYE015054
BRAKE ROTORS.
Ford Explorer UN UP UQ US 1996-2001 brake rotors!
Rotor diameter - 285mm - OEM YL2Z-2C026-BA
Minor park brake diameter - 183mm
Centre hole - 71mm
Marked Bosch 2539203 & F57A2C026AA
Ford explorer brake rotor F57A2C026AA.
REAR BRAKE PADS.
Brake pads rear For Ford Explorer UN UP UQ US 1996-2001 DB2171.
This may help.
