Speedometer cable for 1966 RHD mustang
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Menu ≡
Help
Login
Register
Help
Login
Register
Tech Torque Pre 1973
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Speedometer cable for 1966 RHD mustang (Read 2342 times)
torrus
Pony
torrus
on:
December 15, 2021, 06:25:07 pm »
The speedo needle bounces between 50 and 70 MPH when the car is doing about 60 MPH. Have removed the existing cable ( both inner and outer) and there appears to be a slight kink in the inner cable next to speedo. So I have purchased a new complete setup for a manual 66 manual mustang which is too short. Car is auto but was told RHD need manual cable. The cable I removed was between about 500 mm longer than new one. Didn't need all the extra length. So I assume one of the previous owners has used a cable from a different car or had one made. Can someone advise me of other complete speedo cables from other cars that might suit or a cable manufacturer in the Illawarra /Southern Highland area. RHD with a C4 auto. Thanks
Logged
muzzieat9
Stallion
muzzieat9
Re: Speedometer cable for 1966 RHD mustang
Reply #1 on:
December 15, 2021, 07:51:00 pm »
Recently replaced my speedo cable for the same jumpy needle. Used manual cable and it was the right length for 65 auto RHD. As you'd expect it was a pain to fit at the dash end, but wasn't too tight as far as routing goes.
Logged
torrus
Pony
torrus
Reply #2 on:
December 15, 2021, 08:31:07 pm »
Did you bring the cable through the original speedo hole in the firewall? Maybe I have been given the wrong cable because it is about 300 mm short.
Logged
Clubman7
Worked
Cruising.
Car: 1966 coupe, 2016 GT.
Clubman7
Reply #3 on:
December 15, 2021, 10:01:35 pm »
Got a cable for a Falcon XY.
Car is converted to RHD.
Fits good.
Logged
torrus
Pony
torrus
Reply #4 on:
December 20, 2021, 02:11:48 pm »
Clubman 7. With the XY cable did it fit through the original speedo hole in the firewall or did you drill one on the right hand side of the car?
Logged
Tempest
Thoroughbred
Tempest
Reply #5 on:
December 21, 2021, 07:05:38 pm »
I used a Lokar cable that you cut to fit.
It's quite long out of the box, around 2m, so plenty long enough for a RHD
Logged
Clubman7
Worked
Cruising.
Clubman7
Reply #6 on:
December 24, 2021, 04:59:20 pm »
Speedo cable has a new hole drilled for it through fire wall.
Logged
Print
Pages: [
1
Go Up
« previous
next »
