Another engine vibration
minipete:
I checked the timing today. It was set at 11 deg BTDC 7 years ago and not altered since.
It now reads 20 deg BTDC. The car still runs perfectly and I would assume at 20 deg I would get some kick back on the starter (it doesn't).
This is suspiciously like the outer ring on the balancer has slipped about 1cm. Probably enough to make a vibration.
I can't get a good close look at it so will pull it off and inspect.
Thanks Sam for the call.
minipete:
Pulled the belt pulleys off and the balancer looks fine.
No sign of perished rubber and the outer ring is solid as a rock. I'd happily replace it if I thought it would do any good.
Also the balance weights are on the inner ring so if the outer slipped it should not cause a vibration unless it was severely misaligned (it's not).
I marked where the key is in comprison to the TDC mark in the hope of finding a photo on line for comparison.
Pete
Navigation
[0] Message Index
[*] Previous page
Go to full version
