Technical & General Discussion Area > Members Cars
'69 Mach1
jiffy:
Well - i did a little one almost by accident, but I think I'd have to be particularly hard on it to melt some rubber with tall tires and a Close Ratio toploader running through 3.00:1 gearing.
Time will tell - I've done about 150km's now, about time for it's first oil change.
AussiePhil:
Hey Jiffy,
Great transformation from this photo!
https://www.428cobrajet.org/forum/gallery/184-230420234749-4963946.jpeg
The government gives out incentives for all sorts of crap! Maybe Car Manufacturers should do the same on total rebirths of bring back from the dead stories like this!
jiffy:
Thank you sir!
GEOFF289:
--- Quote from: jiffy on August 28, 2023, 12:13:52 pm ---ok - bought a MSD distributor spring kit and had a play in the weekend and got the advance where I wanted it. 12 initial, no real advance until about 1,500rpm, then progressively advances until about 4,500rpm when it has around 24 mechanical or 36 total. Seems really happy, fingers crossed.
--- End quote ---
I put one of these in mine to fine tune the ignition timing. Very happy with it.
https://progressionignition.com/
jiffy:
--- Quote from: GEOFF289 ---I put one of these in mine to fine tune the ignition timing. Very happy with it.
--- End quote ---
I imagine it would be fine, but I am trying to keep this as numbers matching as possible. All the date codes and part numbers line up...
Navigation
[0] Message Index
[*] Previous page
Go to full version
