Just gauging interest on an upper control arm that Mike Maier is contemplating putting into production. Your thoughts and comments would be appreciated. Not sure of the pricing yet, its a lot of work to produce a really good stock UCA like this so it may not be viable.
Its a tubular arm that uses the stock spring perch but includes:
Screw in ball joint (high quality and reliability)
Delrin bushings
Hardened shaft with slugs to mount different years
Built in 4 degrees of caster
Tubular construction
Fully TIG welded
Shaft and bushings make it fully rebuildable
Looks the same as his MOD1 coilover arm below but for stock springs and shocks.
https://mikemaierinc.com/wp-content/uploads/2015/07/IMG_3238_Web.jpg
