No not run in , almost finished being built
He has put in a hi flow milodon 189 t stat
Block is bored to .030 over
Also what I didn't mention is that it's got power steer (with saginaw pump) air con (putting in new sanden compressor)and it's automatic.
Will a 3 or 4 row rad from mustang parts supplies be ok ?
I went to a radiator shop and they said they can get me a 103 or 128 tube radiator but can't remember the size of the tubes in the same width as the stock one
stock tubes are 1/2" x 1/8". You could get a 4 row but then you should have an electric fan and there may not be enough room, however, you can mount a pusher fan to the front of the ac condenser if it will fit or possibly 2 small pushers etc.
at the very least i would use a 3 row high density rad with stock size tubes and a good mechanical fan and shroud, but i'm pretty sure you will still need to add a pusher fan to the ac condenser.
there should also be at least 1" between the ac condenser and the rad, and a little more clearance would be better.
also, a cross flow rad will cool better and you can use the passenger side outlet pump with a flex hose to connect the rad to the pump if you want.
the 67 rad shaunp mentioned in a 3 row cross flow high density big tubes will work without a pusher fan in front unless you live in darwin. i think you can mount it without adding holes to the core support by making four 1 1/2" long x 3/4" wide flat metal brackets to mount it to but shaunp knows for certain.
