Technical & General Discussion Area > Tech Torque 1974 to 1978
78 Mustang drive train swap
67FBGT:
Info in that article states:
--- Quote --- There was also a C3, a light-duty, French-produced three-speed used in the Mustang II. It looked similar to the C4.
--- End quote ---
I think you'll have to ask around locally and see if you can borrow a C4 either regular or with small flex plate for a test-fit. Any auto trans repair shops around your way who might have something sitting out back of the workshop?
GEOFF289:
C3 was only used in 4 cylinder and maybe V6 Mustangs and Pintos which were built on the same platform.
Husky350:
In regards to the BTR 4 speed you tried to fit, they are a shitload bigger than a c4.
scedd1:
--- Quote from: Husky65 on November 17, 2017, 10:02:18 pm ---In regards to the BTR 4 speed you tried to fit, they are a shitload bigger than a c4.
--- End quote ---
But i didnt have any trouble fitting a BTR in my 68, which originally had a C4, so you would thinkl the tunnel is the same in a 78.
GEOFF289:
See post 4 above. '78 tunnel may be smaller.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
