OK so I thought I better bring some closure to the thread! The job has been done for a while now and the car handles very well. Below is the story.
Here's a gallery of the outcome:
https://imgur.com/a/aP2SVPd which is basically the same as my old mans mustang that I posted higher up in this thread.
What was done:
1) XF box
2) drag link welded
3) Open tracker roller bearing spring saddles
4) King springs KFFL57
5) KYB Excel G shocks
6) Power Steering Pump
While the conversion was done, I knew I had to replace the spring saddles as they were worn so those were done at the same time. I decided to spend a bit more and get OpenTracker bearing saddles as there's been many good reviews about them reducing bind. The conversion took about 3 weeks to the installers credit. The box has a support plate welded on the reverse side of the chassis rail to strengthen it. Also put a hole where you can adjust the steering box if needed. No cutting of the chassis rail.
When I got the car back I was pretty worried - the bump steer was massive. I thought I was in a bit of trouble as I assumed the geometry was all out of whack. A few months passed of me driving it on and off and I decided I needed to get it addressed - I couldn't live with it.
Speaking to the installer as well as Matt @ Hendersons suspension I got some great advice - the car was moving a huge amount vertically on braking but especially acceleration. Matt theorised that slack, old springs combined with the bearing based spring saddles (which are designed to free up the suspension from binding so it can do its job better) was extending the steering geo way further than designed causing the bump steer. In went the King Springs KFFL57 (based on recommendations on the forum) and KYB Excel G and the difference was night and day, and the bump steer is gone - that said, I don't notice any bump steer anymore after driving it around for a few months.
To give you some idea of how far gone the old springs were - the KFFL57s are designed to lower the front end of the car, but they actually RAISED it... by about a cm. So the old spings had had it. The car still looks good, it's low enough for me at the front.
It''s a pleasure to drive. The car already had a 1 inch sway bar but it stays pretty flat and I feel I can go almost twice as fast in cornering. The King springs made a huge difference to the enjoyment I get out of the car, not to mention the power steering. If anyone has old springs still in their Mustang, definitely go for the King Springs.
All in all a great outcome, very happy.
