Ok so we spent the last two days doing the change over to 4bbl
Installed performer manifold
Installed Autolite 4100 I purchased all reconditioned from forum member
Sat it on a stock 1” Aluminium spacer that includes the PCV valve pipe connection
Installed new petronix dizzy
Installed new choke tube (at least the top one as the bottom one is still broken off in the stove. But we think the top should function ok until the new stove arrives from the US. Maybe just a little slower to warm up as it continually draws fresh air through the stove rather than recirculating heated air via the bottom return pipe.
Problem: Very rough idle, seems to run ok at 2000 rpm but idle is rubbish
Any leads/suggestions for my mechanic so we can chase it down? If we cant I’ll trash the carb and buy something new
We are using the baseline flame thrower coil that was driving the igniter in the old dizzy no problems and I believe it is suited/matched the the base petronix dizzy.
We also installed the newly reco’d power steering canister that I had painted and polished only to have it piss oil at the return pipe joint which was obviously fractured
. So ripped it out and silver soldered it before another repaint and hopefully successful install on Monday
