Fender Bolts and paint
Author Topic: Fender Bolts and paint  (Read 3674 times)
Offline Gastill
  • Old Boy
  • Name: Greg
  • Car: 66 K Code
« on: April 24, 2017, 08:32:34 am »
Hi, I'm sure this has been a previous topic, but I've got to ask
When reinstalling newly painted fenders, and using the correct star washer bolts. Is there a trick to installing the bolts and preventing  damage to the paint. I'm mainly concerned about chipping when doing up the bolts
Any advice on this is welcome
Greg
« Last Edit: April 24, 2017, 08:34:36 am by Gastill »
The smell of burning rubber reminds me of losing my virginity.
Offline birdman
  • Name: John
Re: Fender Bolts and paint
« Reply #1 on: April 24, 2017, 04:36:45 pm »
Clean all the threads up so the bolts thread in easier. Use a hex socket and slowly tighten them up if any chip have your touch up paint on hand
Offline unilec5544
  • Name: Neil.
« Reply #2 on: April 24, 2017, 04:45:08 pm »
Unfortunately moving the fender to adjust the gaps to hood and door can cause chips, just use touch up paint once you have the gaps correct. A lot of people drill a very small hole just under the bolt head so that if you ever need to remove the panel, you just need to line up the drill holes to get the fender into the original position.
Hope this helps.
« Reply #3 on: April 24, 2017, 08:27:16 pm »
I saw a guy used bits of ice cream lids under the bolts when moving around for getting gaps right.  Once the happy with your gaps, remove the plastic & refit each bolt.
Offline HAMBURGLAR
  • I NEED MORE MONEY
  • Name: mark
  • Car: 66 A code fastback 6R09A
« Reply #4 on: April 24, 2017, 09:20:06 pm »
I tried this idea with the ice cream container and it worked a treat. A little bit of mucking around but well worth it.  :thumb:
66 A code fastback 289w , t5 , 3.8truetrak.
56 F100 Deluxe custom cab. Major frame off resto. 347w , AOD , Custom 9inch , 3.7 powertrax , IFS , Parallel 4 link rear. Airbags , Low enough to kill ants. Still in progress.
Offline Gastill
  • Old Boy
  • Name: Greg
  • Car: 66 K Code
« Reply #5 on: April 25, 2017, 09:51:55 am »
Howdy
Many thanks for the advise guys, very much appreciated.
Off to buy some ice cream
GA
« Reply #6 on: April 25, 2017, 11:10:55 am »
Yep, any thin flexible plastic lid will do.
Offline HAMBURGLAR
  • I NEED MORE MONEY
  • Name: mark
« Reply #7 on: April 25, 2017, 11:36:33 am »
Howdy
GA
  Don't forget to drill your holes in the plastic before you cut out the pieces champion.  :thumb:
« Reply #8 on: April 25, 2017, 01:24:27 pm »
Offline jademustang
« Reply #9 on: April 25, 2017, 08:59:29 pm »
great, thanks Shane
Offline GT Sally
  • MOCA NSW member since 2008
  • Name: Gazza
« Reply #10 on: April 25, 2017, 09:38:34 pm »
use doner bolts or the like, after you have correct alignment, replace one by one bolt with the newly painted bolts.....use a wrap of masking tape or glad wrap or even better, a section of glad sandwich bag inside the socket....if all fails, colour can be "blown-in" with a low pressure gun.
If you haven't grown up & matured by the age of 55, (65 now & nothin has changed) YOU DON'T HAVE TOO.....Gary
