hi Bac
Just found one in the barn 7/8"back of pulley to centre of groove .out side of pulley is 6 5/8"" o/a. 3 groove , hole centres 60mm
Hey Stormin, thanks for that!
All the measurements of your pulley are spot on apart from the outside diameter - anything bigger than 6-1/8" would foul the water pump pulley.
After some further investigation it looks like my '68 302 block has been fitted with a crank and balancer from a later year 302. This has pushed the mounting face for the crank pulley about 0.9" further out than on a 1960's 289/302 and is the reason I'm having a bugger of a time finding one that lines up with my factory brackets and water pump.
I have just ordered a billet aluminium jobbie from CVF racing in the US that was designed for later year engine components transplanted into '60s cars and it should line up according to the measurements they gave me. Of course I won't know for sure until it gets here...
In any event, I reckon you have a fairly rare pulley there (maybe applicable to the '69 Boss 302) so it would be worth holding on to.
