bummer.
what oil are you using?
how hot does your engine run?
what is the hottest it has ever gotten?
looks like it heat seized to me.
as mentioned, take it apart and measure the cylinder to bore clearance, however before you do that, put the pistons that are on the end of the cylinders, on tdc and measure how far below the block they are.
give us the numbers on the top of the pistons
measure the pistons for wear.
measure the ring gaps.
if all is good, you can get a sleeve in just that one cylinder.
