https://youtu.be/CkYmjZv0Rno
Let me know what you think.
I looked at their site and their engines and I wouldn't consider buying an engine from them unless I knew the exact brand of every single part and push rod size and thickness and valve spring type and installed pressure . They also dont say they use a high perf oil pump drive or what distributor gear or what material the camshaft is made out of or the connecting rod length or whether they zero decked the block which should included squaring it to the crank.
they list 4 different types of pistons for their 450 stroker, so do they install 4 different types in every engine . also 2 of those pistons are made from 4032 material and one is made from 2618 and another could be made from hyperutectic material, and those are vastly different, and if you use a power adder with 4032 or hyperutectic material pistons, they are more likely to grenade if it has detonation.
they also fail to mention exactly what brand of chinese rocker arms they are using that are virtually guaranteed to break or the rocker stud size etc.
are the new water pump and crank damper chinese?
I also didn't see any mention of a warranty not that it would do you any good 6000 miles away.
basically, they put a lot of text up to make their engines sound impressive but tell you very little about specifics, kinda like a politician does.
https://www.customcrateengines.com/engines/ford.html
