I've gone with the 8352. What I think people are telling me is that the pertronix is better value, but the msd is just better. Anyway I didn't need a factory look and I'm sure it'll do the job. Now, do I use the vacuum advance?
Xln't, but just for your info, Pertronix makes a shiny billet aluminum one that has everything the MSD one does for only $265.00 usd.
As I mentioned, you will need to set your timing curve and I would set the vacuum advance to only add 5 to 6 degrees of advance and plug it into ported vacuum, not manifold vacuum.
This is the exact one for $135.00 less than the MSD..and the black cap will match the color theme!
