I have an export brace and a monte bar.
Cheers fellas. Providing I can ensure there is nothing wrong with that upper CA then shims it is. When replacing an item with another item that is supposed to be the same/similar but getting a massive camber change it just rings alarm bells.........
For what it is worth I got a reply from CJ's regarding the UCA length;
I measured the control arm and I got 11 3/8” to the back of the mounting nut as you had pictured. Overall length is 12 1/8”. Hope this helps you.
Not sure that he has measured the same as me but gives me something to go on. From what boofhead has said above changing the spindle should have made no difference to the camber so that pretty much eliminates the UCA length as being an issue anyway.
