barnett I tried what you said and advanced it 4 deg more than it was and i cant hear it ping. It still starts fine when the engine is warm. It ran a bit sluggish though.
Xlnt . . OK, based on your info it should have more power so I would test it again then retard it 4 degrees and try it again . . you can take the wrench and timing lite with you . . you only need to drive it 1/2 mile to test it . . driving further is useless.
Do the test from a stop 3 times and the test fro. 20 kph 3 times then retard4 degrees and do the same thing . . it is basically not possible for it to be slower now, it just doesn't work that way.
You must do the test exactly the same way every time.
The fact that it has no hesitation means it is times and jetted very close.
Part of the reason its slow is due to your 3.00 gears and std eddy intake manifold.
