Thanks to all involved here. I'm meeting with builder when engine is pulled down. Will insist on new cam ARP studs and felpro gaskets, carter fuel pump and new oil pump and airtex water pump
why dont you just buy these parts and hand them to him
if you are talking about arp bolts for the rods, you dont need them . . if you want to make them stronger, all you need is arp rod nits . . he will need to check the rod size after he torques them.
also, dont forget about the cylinder bore and the crane lifters etc..
it might be better if you just write down exactly what we suggest and hand it to him and tell him to do it . . as i mentioned before, i have built a zillion engines and on a simple project like this, i am ecstatic if the owner brings me a list and says this is what i want as long as they are not crap parts.
i never did understand this arrogant attitude some engine builders have . . its not f'n rocket science.
a bosch water pump is also fine.
the oil pump should be a standard mellings . . i would take it all apart to make sure its clean inside first.
