I think the major downside is , when fitting to a older car you can't have computer controlled variability . By that I mean in the factory application as you speed up the ECU (cars computer) tells the electric steering to not be so severe , so on the open at 110 kph it's not the same as if you were in woollies car park. A mate bought electric column from the wreckers out of a rebadged Aussie Opel. $300 from memory, then got a manual control box from the UK which with 3 settings to replicate the ECU. Bit of spline machining and hey presto . Not on the road yet thought. Reckon the manual setting would be a pain / bordering on dangerous if you forgot to change from car park mode when avoiding a rabbit at 110 kph!!
I'll stick to Arthur Bishops design.
