Pedders or Kings Springs to lower front on 65 Coupe ?.
Author Topic: Pedders or Kings Springs to lower front on 65 Coupe ?.  (Read 19866 times)
Offline fastrc
Re: Pedders or Kings Springs to lower front on 65 Coupe ?.
« Reply #25 on: November 17, 2014, 10:57:17 pm »
Thanks everybody for your help, my King Springs were delivered today and Koni's arrive tomorrow.
Looking forward to the install.
Offline griff
  • 65GT Slowback
  • Name: griff
« Reply #26 on: November 17, 2014, 11:34:04 pm »
Giddyup.
you get that .....
Offline jlewis
« Reply #27 on: February 01, 2018, 10:15:24 pm »
Gents,
Any idea on the Kings part number for stock springs?  I'm trying to recover from a 2"+ lowering at the front that has caused new paint work damage with new slightly larger tyres (long story, bad math).
Cheers.
Jeremy.
Offline birdman
  • Name: John
« Reply #28 on: February 01, 2018, 11:01:46 pm »
Gents,
Cheers.
Jeremy.
No idea but I just fitted the KFFL59's - 205/70/14's plenty of clearance. 650mm from highest point top to bottom level ground
« Reply #29 on: February 02, 2018, 08:36:31 am »
Kings 59's are lowered 6 cylinder Cortina spring so standard height Cortina spring may work. But 59's are not too low generally.
Offline jlewis
« Reply #30 on: February 02, 2018, 03:53:45 pm »
I bought 225/60/15 and I knew the car was already lowered.  Having already stuffed up the new paint job I'd like to keep well and clear.  I've read that KKFL-0 suit as well and are not as lowered, but I'd still rather aim for stock.
« Reply #31 on: February 02, 2018, 04:05:26 pm »
Just give Kings a call, or if you're in Qld ... go there.
« Reply #32 on: February 02, 2018, 04:05:54 pm »
No they are lowered and heavier rate they are a Falcon spring.  you can tell by the part number. KFFL = King, ford  front low.
I have built a 65 for a forum member it has KFFL 59's 225/60/15 , runs a 351 and AOD, auto , AC etc so plenty of weight in the front and the guards sit above the Tyre no trouble also has 5 leaf reverse eyes in the back  same thing has clearance to the wheels.
I would try the 59's first frankly.
Offline jlewis
« Reply #33 on: February 03, 2018, 09:55:51 am »
I did call Kings directly on Friday, they recommended KFFS-02, which is for a same era Fairlane, stock height.
Offline birdman
  • Name: John
« Reply #34 on: February 03, 2018, 01:13:33 pm »
Good luck cause i am positive it'll raise it up to 4WD height...
PS i'm sure shaunp will chime in, he's an expert
« Reply #35 on: February 04, 2018, 09:22:11 pm »
Only ever put 59s in them and trim if it needs to be lower. I've never tried to get one Standard height
Offline HAMBURGLAR
  • I NEED MORE MONEY
  • Name: mark
  • Car: 66 A code fastback 6R09A
« Reply #36 on: February 04, 2018, 09:45:04 pm »
I used the 59's and took off another 15mm which gave me another 30mm off when installed on car. Should of gone 10mm instead for 20mm lower .
« Last Edit: February 04, 2018, 09:49:57 pm by HAMBURGLAR »
66 A code fastback 289w , t5 , 3.8truetrak.
56 F100 Deluxe custom cab. Major frame off resto. 347w , AOD , Custom 9inch , 3.7 powertrax , IFS , Parallel 4 link rear. Airbags , Low enough to kill ants. Still in progress.
« Reply #37 on: February 05, 2018, 09:29:19 am »
That looks pretty good to me.
  • Car: 1967
« Reply #38 on: February 05, 2018, 01:58:42 pm »
So how does the KFFL-59 spring compare to a stock '67 spring, if it is actually for a Cortina? (shaunp's post somewhere above).
Is it slightly or a lot stiffer, single or progressive rate?
(Sorry but prefer to ask the knowledgeable ones on here, rather than the King tech dept).
« Reply #39 on: February 05, 2018, 03:01:05 pm »
Both progressive and stiff compared to mustang.  The KFFL0 is a 6 cylinder falcon spring
« Last Edit: February 05, 2018, 03:29:01 pm by shaunp »
Offline mcarnage59
« Reply #40 on: February 05, 2018, 03:25:31 pm »
Certainly don’t class myself as knowledgeable. Can only offer personal experience!
Put KFFL - 59 on my 65 and had the rears reset an 1” lower. Rears were already and good quality 5 leaf. I don’t run high end shocks just KYB gas adjust. Ride and handling difference after the KFFL - 59 is chalk and cheese even though I still have pretzel sway bar.
Firm positive ride with far less float and improved steering. Best money I’ve spent on the car so far from a cruising enjoyment point of view.
Always dreamed I'd have one!
Offline jlewis
« Reply #41 on: February 17, 2018, 02:24:50 pm »
UPDATE:
I decided to go with KFFL59's, and Koni Classic adjustables.  I finally finished one side this morning, dropped the vehicle back down, and I've gained 10mm.  It might be enough, and I'm hoping that I don't lose a couple of mm's when I do the other side.  I've bounced it (not excessively), and I've got no rub.  To what extent should I test this?  I might not be thinking clearly about this but besides coming out of a steep driveway am I going to encounter a scenario where I'll have my wheel turned and a lot of weight on the front of the vehicle (besides any Dukes of Hazzard moments)?
I really want to make sure there will zero rub before I go back to the paint shop to get the paint repaired (again).
Thanks.
Jeremy.
« Reply #42 on: February 17, 2018, 04:35:33 pm »
Wise choice on the shocks, get an alignment and make sure it has some neg camber as well. are the arch lips rolled?
  • Car: 1967
« Reply #43 on: February 17, 2018, 10:17:34 pm »
So if I'm understanding the above feedback, the KFFL59s lower a stock Mustang by about an inch?
There is also mention of the KFFL0 which I'd thought from posts in the past was the spring of choice, now it's the KFFL59?
« Reply #44 on: February 17, 2018, 10:42:43 pm »
59's for 65-66
0 for 67 on
Offline jlewis
« Reply #45 on: February 18, 2018, 07:55:35 am »
Shaun,
Lips are definitely rolled.  In fact my paint guy reckons that the paint wouldn't have cracked if the the arches weren't lead wiped.  Total measurement from ground to lip now is 610mm.  Actually in saying that now I think I've only picked up 5mm not 10mm.
Offline 289 vert
« Reply #46 on: February 18, 2018, 10:00:27 am »
If you relocate the spring perch. you'll gain about 1/2" in height. As well as getting a better motion ratio. It will increase the spring rate though.
"Never argue with an idiot. They will drag you down to their level and beat you with experience."
Offline birdman
  • Name: John
« Reply #47 on: February 18, 2018, 04:27:43 pm »
Well i fitted KFFL59's stating 30mm drop but it only dropped 20mm, i'm guessing due to the sag in the 50yr old springs. So every car will be slightly different.
« Reply #48 on: February 18, 2018, 04:27:53 pm »
Shaun,
You can pack the top of the springs to the tower if needs be, you can buy urethane spacers.
Offline birdman
  • Name: John
« Reply #49 on: February 18, 2018, 04:32:58 pm »
Maybe hasn't got any spacers fitted at all, and maybe no rubber mounts on spring perch either.
PS you mentioned 225/60/15, that's around 650mm/25.63inches so your guard is still over the tyre if it measures 610mm
« Last Edit: February 18, 2018, 04:38:43 pm by birdman »
