My First 67 Coupe build.
Author Topic: My First 67 Coupe build.  (Read 64800 times)
Re: My First 67 Coupe build.
« Reply #25 on: November 17, 2014, 06:21:16 pm »
Its a pretty good shell, Id just repair it then stick it on a Car-aliner and tweak it. You can take the floors out of them no trouble just support the rail extentions with RHS welded across the bottom of the sills.
Offline CraigF
  • Name: Craig
« Reply #26 on: November 23, 2014, 10:04:34 am »
Hi every one.
I've been looking over the bare shell of my 67 and have come across a bend on the boot floor on the left side. On inspection I think it should be straight like the right hand side.
All the rear rails are straight and in really good condition and the actual wheel well looks good.
I know the rear qtrs. have had some damage and need replacing but I thought the boot floor looked good.
Any ideas???
Thanks.
The ben is along the wheel arch edge on the left. I have attached a pic of both
Offline sea67n
  • Name: Sean
« Reply #27 on: November 23, 2014, 10:46:04 am »
Any chance that trunk area has been replaced previously and the bend has happened when putting it in there, have gone through my pics and attached the best I could find from mine in that area, although looking at it again, the shadows make it look deceiving, the bend does go up past what appears to be a join.....
« Last Edit: November 23, 2014, 10:54:16 am by sea67n »
R_Beckhaus
  • Guest
R_Beckhaus
« Reply #28 on: November 23, 2014, 10:48:33 am »
Sean67, yours seems to have a similar bend as well. I'll go and check my '68 and see if it has it. Back soon.
Cheers, Ron B
Offline sea67n
  • Name: Sean
« Reply #29 on: November 23, 2014, 10:58:05 am »
Cheers, Ron B
Are we looking at the same spot Ron??? mine does appear to have something near the trunk filler left section.... Im looking right up against the wheel arch, Ill find another shot if I can
R_Beckhaus
  • Guest
R_Beckhaus
« Reply #30 on: November 23, 2014, 10:59:09 am »
I'm back. My '68 boot recess, LHS has a bit of a bend about 10-15 cm back from the front (forward) corner, and is about 10 degrees. Hope this helps.
Cheers, Ron B
Offline sea67n
  • Name: Sean
« Reply #31 on: November 23, 2014, 11:01:11 am »
I think this one shows a clear bend but still not sure if its in the same spot we originally talking about
R_Beckhaus
  • Guest
R_Beckhaus
« Reply #32 on: November 23, 2014, 11:01:28 am »
I thought he was referring to the disparity of shape in the fuel tank recess edge. The left has a kick inwards. I could be wrong. My eyes are old and grey.
Cheers, Ron B
Offline sea67n
  • Name: Sean
« Reply #33 on: November 23, 2014, 11:04:20 am »
Cheers, Ron B
Yep your right Ron, I thought we were referring to a kink in the actual flat surface of the metal inside the wheel arch, I see exactly what you talking about now, yeah mine has exactly the same, your eyes are still doing well mate
R_Beckhaus
  • Guest
R_Beckhaus
« Reply #34 on: November 23, 2014, 11:04:33 am »
Sean, Yours is same same as mine. Look at your green pic at the edge of the tank recess, at the front and there is a slight bend inwards. That is what I thought Craig was referring to.
Cheers, Ron B
R_Beckhaus
  • Guest
R_Beckhaus
« Reply #35 on: November 23, 2014, 11:05:34 am »
OOPS! replied too quickly!  :thumb:
Offline sea67n
  • Name: Sean
« Reply #36 on: November 23, 2014, 11:06:17 am »
Cheers, Ron B
yep, I need another coffee to kick the brain into gear
Offline CraigF
  • Name: Craig
« Reply #37 on: November 23, 2014, 09:18:56 pm »
Hey guys thanks for the updates earlier today, I don't think the picture was very clear so I have added a line around the raised section on the floor pan.
It looks so symmetrical I appears as if it should be there but I think it is either a mistake from factory or a bad repair. Both ways I think I need to fix it.
 Thinking off the wall here and I know I have only just started this project but maybe a mini tub kit would fix it?
I am currently in the planning stage so anything goes at the moment.
Have a look at the drawn on picture and tell me what you think.
Craig
Offline shelby_mustro
  • Name: Ryan
« Reply #38 on: November 23, 2014, 11:49:19 pm »
Checked out mine it's flat... it's weird how yours dips like that....
1965 Ford mustang coupe
hipo 4bbl 347 windsor v8
t5 5 speed manual
4 wheel power assisted brakes
Other cars
1967 mustang coupe 289 c4 red
Offline sea67n
  • Name: Sean
« Reply #39 on: November 24, 2014, 12:03:44 am »
Craig
ahhh yeah mate that is what I originally thought you were talking about, mine is definitely flat as you can see in the pics, back to my original thoughts that it might be from a repair, the seams around where the petrol tank sits seems to much more visible on yours, regardless I think there are others here more qualified to let you know what the effort of that might be or if it really needs to be fixed
Offline CraigF
  • Name: Craig
« Reply #40 on: November 24, 2014, 07:58:57 pm »
Thanks for update. Have a panel beater coming over on the weekend so we'll go over it and form a plan of attack.
quick question for everyone out there. Know if mini th s are legal in Qld?(
Offline CraigF
  • Name: Craig
« Reply #41 on: November 24, 2014, 09:15:30 pm »
Sorry I mean't tubbs
« Reply #42 on: November 24, 2014, 09:15:57 pm »
Craig
I've seen others like it. Think I have one like it now Ill check tomorrow
Offline CraigF
  • Name: Craig
« Reply #43 on: January 17, 2015, 02:21:47 pm »
Hi all. It's been a few weeks since I last posted anything and I have progressed a little. I have built a rolling jig and mounted the shell onto it with the view to completing the major body work on it. I the propose to transfer it onto a rotisserie to finish the body. I have cut the floor pan out and it is all prepped to be welded into place over the Australia day weekend. The plan then is to support the shell some more under the A pillars to prevent any sag and cut out the dash, firewall and aprons to convert it to RHD and prep it for a fully independent suspension.
I'll post a few pictures over the next few days as I get around to getting them off the camera.
Quick Note.......Plasma cutters are awesome!!!!
Offline CraigF
  • Name: Craig
« Reply #44 on: January 17, 2015, 02:30:30 pm »
A few Pictures as we went along
Offline CraigF
  • Name: Craig
« Reply #45 on: January 17, 2015, 02:34:50 pm »
This is the floor pan we purchased from Sydney Mustangs. A great quality reproduction part. Metal guage was great and the fit is pretty good as well. We only encountered on place that will need a little adjustment just in front of the right rear wheel. It didn't quite match the shape required but easily repaired.
Offline CraigF
  • Name: Craig
« Reply #46 on: January 17, 2015, 03:10:55 pm »
Floor pan sat in place ready to weld in.
R_Beckhaus
  • Guest
R_Beckhaus
« Reply #47 on: January 18, 2015, 12:35:21 am »
It's coming along nicely, Craig.
Cheers, Ron B
Offline CraigF
  • Name: Craig
« Reply #48 on: January 18, 2015, 06:33:15 pm »
Thanks Ron
Long way to go yet!!!
Offline CraigF
  • Name: Craig
« Reply #49 on: January 25, 2015, 08:00:48 pm »
Well hi everyone.
I've had a busy weekend so far with the final weld down of my new floor pan and the removal of my firewall, upper & lower cowl and the dash in preparation for a RHD conversion.
