Best Oil to Use for a 302 Windsor?
Author Topic: Best Oil to Use for a 302 Windsor?  (Read 17219 times)
Offline businesstrader
« on: August 31, 2014, 07:05:56 pm »
I'm planing on replacing the oil in my 302 windsor tomorrow and was wondering what should I use?
Re: Best Oil to Use for a 302 Windsor?
« Reply #1 on: August 31, 2014, 07:26:35 pm »
I use Penrite 30 , and a Ryco Z9 filter .
Offline peter9231
  • Name: Peter
  • Car: 66 convertible
« Reply #2 on: August 31, 2014, 07:41:04 pm »
Hello,
Depends on the year of the 302.
Roller cam engines use a different grade oil.
Ryco filters are made in china now.
Peter.
« Reply #3 on: August 31, 2014, 07:52:14 pm »
How many litres? 5?
« Reply #4 on: August 31, 2014, 07:54:36 pm »
Yes 5 lt it will take it ,put some into the filter 1st and around the seal .
Offline robster
  • Big Mac
« Reply #5 on: August 31, 2014, 08:01:49 pm »
Hey CPU,
Don’t mean to be a spoiler but noticing a fair few emails like these that would be better placed in the ‘Tech Torque Pre 1973’ section.  Or are you being just plain swamped ?
« Reply #6 on: August 31, 2014, 08:05:52 pm »
Yes it should be ,I never looked .
Offline 66RedRagtop
« Reply #7 on: August 31, 2014, 11:11:00 pm »
If it's an original flat tappet 302 Windsor use an SL or earler rated oil with around 1600ppm of ZDDP (Zinc-Phosphate) to protect the valve train. ZDDP content was lowered from SM rated oil onwards. Penrite uses high quality ingredients and has plenty of ZDDP in their classic car oils.
Synthetic oil isn't ideal for older type engines as it tends to seep past the seals and gaskets of the era.
Any branded oil filter should be OK. Avoid plain box products. As said, wipe a skim of oil around the rubber seal before fitting.
Offline Bumblebee
« Reply #8 on: September 01, 2014, 10:56:39 am »
Penrith HPR30, perfect for these engines and loaded with ZDDP.
Cheers Bee
« Reply #9 on: September 01, 2014, 11:09:03 am »
Yeah I think I'll go with Penrite HPR 30. Someone else I know also recommended this. Thanks for the advice!
So how important is the quality of the oil filter? Would something like this be ok:
http://www.ebay.com.au/itm/z9-Ryco-Oil-Filter/261441080417?_trksid=p2045573.c100033.m2042&_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20131017132637%26meid%3D65c20cd7057347a588aa34e1b264f193%26pid%3D100033%26prg%3D20131017132637%26rk%3D4%26rkt%3D4%26sd%3D400412510218
Offline birdman
  • Name: John
« Reply #10 on: September 01, 2014, 11:47:18 am »
 :agree: use Penrite HPR 30 forget the rest.
« Reply #11 on: September 01, 2014, 12:35:16 pm »
Far as I know Ryco is fine but you can get it for just 29 cents more and avoid postage by going round to your nearest Supercheap.
http://www.supercheapauto.com.au/online-store/products/Ryco-Oil-Filter-Z9.aspx?pid=8130#Combo
They also have a "premium" Ryco Z9 they say is better for about $12 I think, but I can't find it on their website.
« Reply #12 on: September 01, 2014, 01:00:24 pm »
Awesome! Thanks for the tip.
Offline 68Coupe
  • MOCA NSW Member
  • Name: Andrew
« Reply #13 on: September 01, 2014, 02:34:31 pm »
I added half a dozen of these to an order from CJ's a while ago @ $6 each to keep me going.
http://www.cjponyparts.com/oil-filter-ford-motorcraft-1965-1995/p/OF1AF/
Yep, and the Penrite HPR30.  :thumb:
« Last Edit: September 01, 2014, 02:37:57 pm by 68Coupe »
« Reply #14 on: September 02, 2014, 11:40:04 am »
Penrith HPR30 in and oil filter replaced. Purrrrring like a kitten now!
Offline nt0351
« Reply #15 on: November 04, 2021, 01:50:13 pm »
try ULX-110 and you'll change your mind
Offline Bucks
  • Name: Dave
« Reply #16 on: November 05, 2021, 03:20:32 pm »
Always used Valvoline engine Armour 10-40 in all my 302s and 289s V8s, some have done over 375,000klm on gas, all on ryco filters, never had a problem.
only problem i had was trying penrite, i found it made the sump and tappet cover gaskets leak on my older 289s and 302s, swapped back to Valvoline.
« Last Edit: November 05, 2021, 03:22:09 pm by Bucks »
