Spark plug type for 347
Author Topic: Spark plug type for 347  (Read 1408 times)
Offline zlat347ci
  • Name: Zlat
« on: August 06, 2014, 07:10:15 am »
Guys,
Wanted to see what people reccomend for spark plug type for 347 and gap?
Ive got a mate that used NGK BPR5EFS-13 , these actually come up for vn commodore v6. But run great on his simmular setup.
Anyone running 10mm leads, any benefits?
Car runs msd 6al
Cheers.
Re: Spark plug type for 347
« Reply #1 on: August 06, 2014, 07:41:53 am »
It depends what heads you have . NGK are the go and a 6 heat range unless its a daily driver in traffic and a big carby then a 5 .
« Reply #2 on: August 06, 2014, 08:26:57 am »
Sorry forgot to answer the other questions . With a msd 6AL plug gap with a engine compression ratio under  or around 10.1 the cap should be about  45 to 50tho ,less for higher compression engines . 8 mm leads are fine 10 if  it's a full on race car .
« Last Edit: August 07, 2014, 08:36:45 pm by GLENN 70 »
Offline zlat347ci
  • Name: Zlat
« Reply #3 on: August 06, 2014, 08:38:21 am »
Great thanks Glen. The ngk I quoted are heat range 5.
I might give them a shot see how they go
« Reply #4 on: August 06, 2014, 08:44:59 am »
No ,it depends on what heads they are . Get onto the sellers of your heads and see what they say ,and a 6 would be better .
