The stuff shown in the link is sort of a one-size-fits-all cheap aftermarket product. Here is a 600 cfm 4100 that was originally on a 65 T-Bird that I went through, put a kit in, etc, last week, along with the seats that I removed from it and replaced. They had the little filter thingies sticking out of them, but I put those in the new seats, which were essentially identical to these. The kit that I used on this one was Walker and it had the number 15255. I don't know if Walker is available where you are, but, it is a decent kit that has most of the stuff that you'll need. No kit includes the vacuum diaphragm for the secondaries, that has to be purchased separately, but, other than that, it's complete and reasonably good stuff. The Motorcraft kit for those is still available and normally runs something in the $50 U.S. range. The float damper spring that goes on the primary side is still readily available and costs about 3 dollars.
Oops. Wrong carb. The carb that I posted the picture of is actually for a 65 Galaxie with a 352. The 65 T-Bird carb was behind it on the shelf. They start looking the same after a while.
