Pulled front and rear windows out, chucked the front window as the window wipers had been run over it without blades and scratched the crap out of it. Back window got washed several times, windexed just a few and once it looked new again, got wrapped up in plastic and stored.
Then came possibly the most prickly job yet....... removing the back quarter windows. I do like figuring things out myself and take a lot of pride in doing so, but come on, really!!!! Easier the second time.
Tip....... undo every bolt you can find with the window up, wind it down and do the same. Pull out the mechanism. Pull out the bump stops and run the wheel guide out the bottom of the runner, lift the window up while rotating the boomerang shaped arm till able to remove........ Or just get someone else to do it!!!
And once out the quarter windows got the same treatment..... acid on the runner and washed off, thorough clean with soapy water and windex not degreaser as the rubbers are still good, polished all chrome. Once looking new again, a good coating of armoural, actually heaps of armoural wrapped with the window in plastic and stored.
