Newton's Law
Horsepower= Torque muliplied by RPM divided by 5252
Horse Power = 853ft/lbs multiplied by 5000 RPM divided by 5252
= 812 HP @ 5,000 RPM = B/S = Crap = Garbage = Rubish
You had better tell Craig to get his dyno serviced and re calibrated. Clearly, you being a mechanic/engine builder should realise this. Any secondary school child could tell you your Torque figure is not correct.
So, given you are hung up on Numbers, let me show you how wrong you are, let me use YOUR ENGINES 427 numbers that you stated.
"Newton's Law"
Horse Power = 653ft/lbs multiplied by (Say)5000 RPM divided by 5252 = 621HP @ 5,000 RPM = B/S = Crap = Garbage = Surely that's not right
Horse Power = 653ft/lbs multiplied by (Say)4000 RPM divided by 5252 = 497HP @ 4,000 RPM = B/S = Crap = Garbage = Surely that's not right
Horse Power = 653ft/lbs multiplied by (Say)5700 RPM divided by 5252 = 708HP @ 5,700 RPM = B/S = Crap = Garbage = B/S, and you know it.
Now you know as does any everyone else these figures are all bullsh#t. Your engine is not and will NEVER reach its Max torque figure at 5700rpm. That is in your words B/S = Crap = Garbage
Let us ponder why, when you stroke an engine (maybe just the rod length) we not alwas see an increase in total HP but we do see a increase of the torque curve and in most cases the total torque figure. So you assumptions based on James Watts Law on HP is not an absolute. Anyone with any engine building experience that has used Engine or Chassis dyno will tell you that, which goes to my previous comments you have no idea what you are talking about.
Let me finsh with this in language you can understand, there are no absolutes, the James Watt law on HP is not an absolute, the combustion engine is not a totally efficient animal. When I was in F1 our engines in 1979-1986 operated at approx 92-94% of it total efficency (again these figures were calcuations only and still are, as there is no way of totally addressing the 100% rule or issue), today they are higher approx 95-96%, a V8 Supercar engine operates at 90+% depending on supplier, and the typical manufacturers production line engines are just above 75% approx, so there are no absloutes. While I have taken offence to your carry on about my car, I am sure you can see that I have a mockery of your figures, so I strongly suggest you think before you decide to slander anyone, because you are no guru buddy. I think someone else stated that the forum was for bench top racing"", well buddy, you have been absolutly beaten.
Oh and I tkink you may have a litle drama with Graig now, he constantly has his as does a number of others in the area have their chassis dyno checked together to ensure that they are, as close as possible to stop these sorts of accuations being leveled to them......... Just stop the B/S, it really is embarrasing, go back to your bench top racing with Blackthunder and the other chosen few, and if I have offended you, tuff, you persisted in carring this thread for far too long........Darryl
