Hi trik 66,
The vaccum secondary spring may be too heavy, not allowing the vacuum-operated secondaries, which utilize and increase in load and engine vacuum to gradually pull open the secondary throttle blades.
However, if your engine has an extremely large-duration camshaft where low-speed vacuum (or lack thereof) is an issue, the vacuum secondary set-up may not always be the ideal setup.
Trans-Am:cool:
