I have an AOI power rack & pinion kit in my 1967 fastback. The self centering issue was quite noticable when first installed but it's fine now that the castor has been adjusted to suit R&P.
When I first purchased the kit, I elected to use my own power steering pump and that works fine as it's out of a 1987 Mustang which has higher pressure and matches up well with the rack.
My original steering column was sent over to Adelaide and AOI cut it to length, machined the shaft end ready to fit the uni joint supplied with the kit.
The steel mounting bracket for the rack is a perfect fit with the original holes in the sub-frame rails and gives the car much more rigid cross member bracing than the standard bent tube fitted from factory (both are in place).
Generally speaking Mario was very helpful and always returned my calls in a timely manner if he was not answering when I rang.
As with most RHD racks, the exhaust headers had to be custom bent to allow fitment of the rack and access to the starter motor.
At low speeds the car steers very lightly as you would want when parking, at highway speeds, the road feel is good and there is almost no bump steer. All things considered, the AOI kit is an acceptable upgrade, but at nearly $3,000.00 it's not something you would do ahead of disk brakes, better suspension, lap/sash retractible seat belts or head rests. I have done all these things as I wanted to make the car safer to drive and that is not done without spending lots of money!
PT
